| Home > Help Needed / General Tech Chat > What bhp will I be running? | |||||||
64 Posts Member #: 8011 Advanced Member |
25th May, 2010 at 11:13:22pm
What Will I roughly be running with this setup?
25th May, 2010 at 11:31:10pm
Massive chambers for high boost and 18cc in the pistons.... Do you know your CR?
25th May, 2010 at 11:38:20pm
This is the engine in the car Rubicon linked to on ebay. If something is worth doing, it's worth doing half of. |
25th May, 2010 at 11:42:33pm
On 25th May, 2010 Vegard said:
Massive chambers for high boost and 18cc in the pistons.... Do you know your CR? I had to skim my head after fitting 18cc pistons. Power depends on head, cam and boost. The T3 camshaft has been proven OTT. I have only just bought this engine setup so im unsure on the compression. Why did you have to have the head skimmed? Yea I've been reading about the avon bar phase 3 and its not great. I do have a phase 2 cam which I will be putting into it. I will be running around 12psi? Do you have a ball park figure for this engine? Many thanks |
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
25th May, 2010 at 11:56:28pm
I'd be worried about the CR a little myself.....
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
26th May, 2010 at 12:05:37am
Im quite new to this, so it might be a stupid question but what is wrong with going lower than 8.5:1 compression?
26th May, 2010 at 12:16:26am
Poor fuel economy and horrible to drive off boost On 12th Nov, 2009 Paul S said:
Gary's description is best |
26th May, 2010 at 07:51:52am
I would change the head gasket, if it's just 'cosmetic' then you will have problems On 11th Feb, 2015 robert said:
![]() 465 Posts Member #: 1972 Senior Member Worcester |
26th May, 2010 at 08:35:20am
I run 7.5:1 and its not horrible to drive off boost at all |
26th May, 2010 at 09:31:41am
On 26th May, 2010 retroracer1380 said:
I run 7.5:1 and its not horrible to drive off boost at all What cam though? On 7th Oct, 2010 5haneJ said:
26th May, 2010 at 09:33:38am
On 26th May, 2010 apbellamy said:
I would change the head gasket, if it's just 'cosmetic' then you will have problems ![]()
26th May, 2010 at 05:41:40pm
I run 7.5:1 and its not horrible to drive off boost at all I used to run my compression as low & didn't think it was horrible either, but when I raised it to 8.4-1 the improvement was very noticeable. |
29th May, 2010 at 07:28:04pm
Maybe i will try raising it up a bit when the heads off next, was just playing it very safe lol! |
1st Jun, 2010 at 09:58:54pm
I am running about 7.9:1 with 9psi metro cam. runs great but feels a little 'cammy' due to the air speed across the head at low speeds making it feel lumpy. i reckon you may be looking at an easy 150 - 160bhp 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
2nd Jun, 2010 at 12:34:22am
i know that engine....lol
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
