Home > Help Needed / General Tech Chat > How to get the brake pedal aligned with accelerator ?
alpa
Member #: 2093
Grenoble, France
The original brake pedal position is too high. I'd like to align it with the accelerator. I don't like the idea of bending the brake pedal.
Is there a standard way to do that, I'm certainly not the first to wonder.
Thanks
Edited by alpa on 27th May, 2010.
I have cut and shut a clutch pedal, but I don't think I'd try it on the brake.
I presume you want to heel-and-toe more easily? I don't have a problem with the standard pedal arrangement, maybe some Yoga would help!!
Maybe moving the throttle would be more semsible, there are pedal extensions available. Is your throttle pedal as high as it can be?
t3gav
Member #: 229
Gavin@minispares.com
kent
What year is the car? I think there is some adjustment on the servo models.
alpa
Member #: 2093
Grenoble, France
It's a 89 carb, no servo.
wil, the brake pedal is too high (I had exactly the same on the other '86 Mayfair), I have to lift my leg to brake, it's a loss of time. Of course I also want to heel-and-toe, I can do it today but I'm slow for the reason above.
Is the clutch the same? If it i made a round piece of allY that was 3/4 thick that raised my master cylinders up effectively lowering my pedals.
Mike
Edited by MikeRace on 27th May, 2010.
differant pedal box? if it were me i would move the accelerator
Jackman
Member #: 984
Westhoughton, Bolton
Couldnt you bend the accelrator pedal up so its at the same height? Or am i completly missing the point here??
Manchester Minis
alpa
Member #: 2093
Grenoble, France
No guys, the problem is not the gas pedal. I can bend it. But the brake is too high, I can not reach it without raising my leg, that's very slow. Once pressed brake and gas are aligned.
MikeRace: thanks, I'll see what I can do.
Hey, how do you drive that things ? I've got big feet (45 French, 12 US), do you have bigger ones ?
I reckon the servo brake pedal is different from the non servo pedal, and I dont mean just the clevis pin hole.
Edited by Sprocket on 27th May, 2010.
graemec
Member #: 1424
Carnforth, Lancs
So if you lower it then it will be more difficult to heel & tow as the brake pedal will be lower than the throttle when pressed.
I was just thinking about that
The non servo pedal is higher as it has to travel more to do the same job as a servo assisted pedal that would travel, perhaps only half as far for the same braking effort.
Edit* I don't have any problems heal and toe shifting with the 'high' pedal
alpa
Member #: 2093
Grenoble, France
As everybody said I can bend the accelerator :) .
The travel of the brake is quite long, that's true. But once disk reached the travel is very short, I don't think it'd hit the floor, today it's quite far from it.
Perhaps I just should make more sport to get the leg faster ?
Yes, a faster leg and lose the cuban heel.
tadge44
Member #: 2500
Buckinghamshire
Why is it not possible to just cut and weld the pedal to get it where you want it - its what I did in different circumstances.
Jackman
Member #: 984
Ive just had another thought.
Have you ever had the pedal box out? Im wondering could it be a warn clevis pin moving the brake pedal higher?
Manchester Minis
I bent my accelerator pedal, and they are spot on. *wink*
fab
Member #: 100
Parisien Turbo Expert
Paris\' suburb
Aren't brakes for gays?
Then you can bend any shaft you want ...
tadge44
Member #: 2500
Buckinghamshire
True - and they only slow you down, anyway.
alpa
Member #: 2093
Grenoble, France
Oh really ? I thought it was a rest plate for my left foot ! That may explain the low mileage I'm getting.
alpa
Member #: 2093
Grenoble, France
I have one a part, I'll see. Thanks.
Owen
Member #: 6496
Somerset
I'm not sure where the difference lies, but you can get different pedals.
My first mini (1980 HL) had stupidly high pedals like yours, but my current mini (1983 gayfair) has pedals that are level with the accelerator.
I've had both pedal boxes apart and next to each other and the pedals are deifinitely different.
On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair
On 31st May, 2010 Owen said:
gayfair
now thats not fair is it *hehe!*
Arnoud
Member #: 1085
Netherlands
how about shortening the master cylinder's rod? That would lower the pedal too and should be easier to weld up than the pedal itself.
Edited by Arnoud on 31st May, 2010.
1963 Cooper
1975 Pick Up
i dont think its a case of you cant weld the brake peddle more like would you drive a car with a cut/shut brake peddle?.. i would prefer not too
tadge44
Member #: 2500
Buckinghamshire
I trust my life with my welding every time I drive my car.
