| Home > Help Needed / General Tech Chat > Oil Level In Tappet Chests | |||||||
27th May, 2010 at 10:01:02pm
Anyone know how high the oil level might get in the tappet chests during normal running?
27th May, 2010 at 10:30:17pm
I would have thought not very high, probably just a spattering/layer (unless there is something wrong)
27th May, 2010 at 10:35:53pm
plenty of splash wil around a 3mm ish level.
27th May, 2010 at 10:39:15pm
I would think that the non holed ones would be almost completely full. I cannot see why not. On 13th Jul, 2012 Ben H said:
27th May, 2010 at 10:43:21pm
27th May, 2010 at 11:07:54pm
On 27th May, 2010 mini13 said:
The tappet chests V, not the tappets. Oh
28th May, 2010 at 07:47:45am
I presumed that the level would be minimal. Its juat that my bodged up breather seems to be leaking oil, but it seems strange that so much oil is getting in it.
28th May, 2010 at 08:28:36pm
Maybe re-examine your "bodged up breather" and make sure the breather pipe goes up at least 200mm before it goes anywhere else - its amazing how far that little bit of oil can get if its not encouraged to stay where you want it to. |
28th May, 2010 at 09:03:13pm
Has the "bodged up breather" got a splash guard over the hole on the inside of the tappet chest cover plate ???
72 Posts Member #: 6792 Advanced Member |
30th May, 2010 at 10:25:55pm
On 28th May, 2010 wil_h said:
I presumed that the level would be minimal. Its juat that my bodged up breather seems to be leaking oil, but it seems strange that so much oil is getting in it. cheers Check your rocker shaft. |
