| Home > General Chat > Uni Help! | |||||||
329 Posts Member #: 3193 Senior Member Torbay, Devon |
28th May, 2010 at 09:05:11am
Hi
28th May, 2010 at 09:41:49am
The stanadard unit for electricity metering is kWhrs
Edited by Rod S on 28th May, 2010. Schrödinger's cat - so which one am I ??? |
28th May, 2010 at 11:16:04am
How much do you know about big gen sets like this? I have a little experience from working on their control systems off shore. The main thing you have to consider is that all the auxiliary systems, fuel pumps, oil pumps, cooling pumps, control system, etc will need an separate supply until the set is online. Also, and again this is only what I have experienced, is that generators are always specified for full load rating, but quite often they are not running anywhere near that so you have issues with them running at inefficient areas of their range and sometime having coking issues. This is particularly apparent when you only have one generator.
http://www.twin-turbo.co.uk
