| Home > Help Needed / General Tech Chat > mpi wont start following front end repaint | |||||||
28th May, 2010 at 11:15:41am
Hi, I have done some paintwork to the front end of my mpi mini this week. After stripping the front end down (lights, wiper motor, bonnet, drivers door etc), the car refused to start. It turns over but wont fire up. Its back together now pretty much but refuses to start.
![]() 299 Posts Member #: 2814 Senior Member Mansfield - Notts |
28th May, 2010 at 11:19:45am
Have you tried the inertia cut off switch? It's on the row of relays on the bulkhead, to the right if I remember rightly....
Edited by TomBooth on 28th May, 2010. |
28th May, 2010 at 11:26:47am
no, but i will give it a try. there is no reason for this to have been triggered though. |
28th May, 2010 at 11:32:29am
Did you start the engine move the car only a short distance and then turn the engine off, before it got anywahre near warm? If so, it may have flooded the cylinders. Whip the plugs out and see if they are wet. On 26th Oct, 2004 TurboDave16v said:
28th May, 2010 at 11:46:14am
My old mpi did the same, turned out the switch had just popped out on its own accord.....
28th May, 2010 at 11:48:05am
Paint on the spark plugs?????? |
28th May, 2010 at 06:44:42pm
i painted the car not an ebay special type engine nic |
