| Home > Help Needed / General Tech Chat > clutch, can not take it off! | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
30th May, 2010 at 04:07:34pm
hi there!
Nothing special! |
30th May, 2010 at 04:09:41pm
with a flywheel puller. I'd guess the big oil seal around the gear on the end of the crank On 11th Feb, 2015 robert said:
30th May, 2010 at 04:28:38pm
ohhh, now i need to buy it :(
Nothing special! |
12 Posts Member #: 1980 Member |
30th May, 2010 at 04:33:57pm
On 30th May, 2010 apbellamy said:
with a flywheel puller. I'd guess the big oil seal around the gear on the end of the crank +1. if the clutch plate has oil on it its skip fodder and has to come of anyway. Its an arse of a job but the only way to get at the seal. |
30th May, 2010 at 04:55:08pm
On 30th May, 2010 chominsh said:
is there any other way to get it out? NO, you need a proper flywheel puller. You could register on one of the other Mini forums where someone would probably tell you to hit it with a 7lb lump hammer from the back through the starter motor hole, but most of us over here like to keep our flywheels in one piece and our crankshafts straight :) Schrödinger's cat - so which one am I ??? |
30th May, 2010 at 05:00:56pm
do i will need any other tools to change this oil seal? Nothing special! |
30th May, 2010 at 05:01:56pm
hahahah :)
Nothing special! |
30th May, 2010 at 05:03:15pm
30th May, 2010 at 05:09:51pm
You need a haines manual ![]() yea i need one ! how much could it be for mini metro turbo engine? is this puller will be ok? Nothing special! |
30th May, 2010 at 05:11:07pm
do i will need any other tools to change this oil seal? A large socket to undo the flywheel bolt (is it verto or pre-verto as the sizes are different ???) and a torque wrench to re-do that bolt to the correct torque afterwards. Otherwise, nothing special - there is a special tool available to remove the primary gear oil seal (which is where your leak will most likely be) and a special sleeve to slide the new one over the splines but these are not essential and can easily be improvised. Otherwise normal tools. Schrödinger's cat - so which one am I ??? |
30th May, 2010 at 05:16:20pm
That's the correct puller, but they are cheaper than that at halfrauds (cheaper than minispares infact) On 11th Feb, 2015 robert said:
30th May, 2010 at 05:24:16pm
You also need to find a way to lock the flywheel so that it doesn't rotate while you are trying to undo the nut. I usually use an old mains bearing in the starter hole sat against the ring gear On 11th Feb, 2015 robert said:
30th May, 2010 at 05:25:32pm
That's the correct puller, but they are cheaper than that at halfrauds (cheaper than minispares infact) you mean halfords? thank you a lot Nothing special! |
30th May, 2010 at 05:33:54pm
yes On 11th Feb, 2015 robert said:
30th May, 2010 at 08:52:36pm
Seriously get yourself a manual. In the 13's at last!.. Just |
30th May, 2010 at 09:30:08pm
please read this, you have alot to learn
Yes i moved to the darkside |
72 Posts Member #: 6792 Advanced Member |
30th May, 2010 at 10:37:57pm
7th Jun, 2010 at 04:22:13pm
You do not have to skip the clutch plate. Get yourself a blow torch and sweat the oil out of the clutch. The second you start to heat the friction material the oil will begin to sweat out. Wipe the oil away and keep sweating the friction material until there is no more sign of oil
Own the day
