Home > Technical Chat > update
1250cinqturbo
Member #: 8432
hello guys! not been on in a while but id thought id pop on and let you no how the cinq is doing!
first things first its had another little power hike with the addition off water/mehtonal injection from Aquamist, the kit runs there 100plus psi pump through a 245cc/hr jet coming in at 10psi, ive combined this with an external washer pump fed water/methonal jet for spraying the front off the cooler when i go for full throttle, the end result has been amazing!
After the hardest run possible i can pull up and open the bonnet and even in all the heat under there the boost pipe close to the TB is covered in condensation and is really cold to touch even on hot days, that part of the pipe is only around 1.5 feet from the jet itself.
So you can imagine the difference on the road with the cold air, its now running 165bhp/155lbsf and the performance is blistering, flicking the swtich for the WI while under full load in fourth results in an instant surge right throught the revs *happy* aswell aswell as providing a far far safer engine against DET and heat damage...result.
Ive also had the car weighed after the interior was striped and its weighed in at 693kgs with quater of a tank off fuel, there is an estimated 30kgs left to strip out so its doing ok lol.
Since the power hike getting the power down has been a nightmare! in the wet even at 10psi im getting wheel spin from fourth at the slightest prod on the throttle and its killing the handling! to combat the handling issue ive fiited some camber bolts for 2 dgrees neg camber which made a huge difference! and a rear strut brace. Also ive invested in a Rally Designes rear antiroll bar kit with poly bushes which ive yet to fit.
thanks
jason
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Sounds like a sweet machine.
A link to some pics perhaps ?
"Try to take over the world!"
pinky if you search his name itbrfings up a build thread
jasen what do your afr's do when the water inj comes in?
thats some good oomph! :)
I'd definatly megasquirt it so you can log stuff *wink*
