Home > Wanted > A couple of parts
advantage998
Member #: 1840
Kings Lynn, Norfolk
* Air vent mounting for inner flitch panel, the part the eyeball vent clips into, and the ducting on the other side.
* Long pot joint driveshaft
advantage998
Member #: 1840
Kings Lynn, Norfolk
Bump
I've got a pair of drive shafts on ebay ending tomorrow, if they don't sell you can have the long one for the cost of the postage.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Thanks Rob
i will have a look for you tomorrow
advantage998
Member #: 1840
Kings Lynn, Norfolk
Thank you
turbominivanman
Member #: 1504
Westbury, Wiltshire
Which side, LH or RH ?
They have a small mark identifying the handing.
I think I have spares of both, and the vents, but will need to check on my return Sat night if it helps.
Richard.
advantage998
Member #: 1840
Kings Lynn, Norfolk
Right hand side, honestly hadn't realised they differed, have the vents them selves its just one of the mounting is broken.
I would be very grateful if you could check over the weekend.
Thanks
Tom
advantage998
Member #: 1840
Kings Lynn, Norfolk
Don't suppose any one has found one? I'm really struggling.
