| Home > Help Needed / General Tech Chat > Joining thin aluminium | |||||||
![]() 611 Posts Member #: 5222 Post Whore Northumberland |
31st May, 2010 at 09:25:47pm
Edited by rosco454 on 31st May, 2010. On 20th Jan, 2011 apbellamy said:
I have a bit of a fetish for tools |
31st May, 2010 at 09:39:39pm
Sliver solder wont do alu mate. Tig is the only way
I seriously doubt it! |
31st May, 2010 at 09:41:03pm
4 rivets Edited by minimole23 on 31st May, 2010. On 7th Oct, 2010 5haneJ said:
31st May, 2010 at 09:49:32pm
Since our company started making machines with Aluminium/ Aluminium condensers, there is a 'technical procedure' to repair damaged tubes by aluminium soldering?! There is a kit for this task wich includes a special solder rod, a masking plate, flux, and full instructions. Basicaly, you can 'solder' the damaged tube with a gas flame.
549 Posts Member #: 5327 Post Whore Dudley, West mids |
31st May, 2010 at 09:51:12pm
Put a picture up. There might be a tasteful alternative that we can come up with. |
31st May, 2010 at 10:15:07pm
Oh well back to the drawing board.Would have helped if I had actually read up on it beforehand at all!
31st May, 2010 at 10:27:17pm
dont forget there is TIG and there is TIG Edited by Sprocket on 31st May, 2010. On 26th Oct, 2004 TurboDave16v said:
31st May, 2010 at 10:36:53pm
No, you need AC for aluminium.
31st May, 2010 at 10:53:02pm
ah crap, yes, I got it the wrong way round. On 26th Oct, 2004 TurboDave16v said:
31st May, 2010 at 11:17:08pm
Cut one the perfect size for the hole then one half inch bigger and sikaflex it on from thr back. bingo.
31st May, 2010 at 11:52:16pm
31st May, 2010 at 11:59:27pm
On 31st May, 2010 cossierick said:
Cut one the perfect size for the hole then one half inch bigger and sikaflex it on from thr back. bingo. Rick Genius! Thanks Rick.Will have to cut a hole in the centre of the larger one as its where a dimple should be on the dash. This pic probably gives more of an idea,Ignore the binnacle as that is most likely coming off.
1050 Posts Member #: 764 Post Whore Staffordshire |
1st Jun, 2010 at 12:00:40am
493 Posts Member #: 3894 Senior Member sallys gap. garden of Ireland |
1st Jun, 2010 at 12:37:58am
interesting stuff.
1st Jun, 2010 at 12:57:33am
Check out this at 05:15
1st Jun, 2010 at 07:13:12pm
i've used the solder type stuff from ebay and i have to say it was bloody good and strong. made a neat job of it. |
1st Jun, 2010 at 11:00:37pm
Techno Welding!, i used to do it in school, very simple to do.
