Home > Help Needed / General Tech Chat > Low oil pressure, std ish 998
My 998 engine has got problem with oil pressure. We've put fresh 20/50 oil in, and on startup it takes around 10 seconds to get oil pressure. When cold oil pressure is around 65 psi, when hot it's around 20psi when idle which rises to 40 psi ish when reved.
I've checked the calibration of the gauge, and checked for shit in the oil pressure releif valve. The bullet has been replaced with a ball bearing.
Is it worth packing out the spring on the release valve, or is the oil pump / shells shagged?? I've got a qualifier race in 2 weeks, and not got a lot of time to strip the engine if it's not needed. Equally I don't want to risk blowing the thing up, as it's putting out fair is power for it's class (51 banannas).
any thoughts?
dischub
Member #: 8143
London
What gauge do you have? The Tim ones can be slow registering pressure
Carl S
Member #: 1761
Stalker
Exact same problem as me, low oil pressure issues when using 20W50 oil. I previously had semi-synthetic and never had any oil pressure issues. The engine has done 85k miles.
Switch to 15W40 semi-synth and see if it helps Jim.
imo if its getting oil whilst its running and is not knocking its ok,
its probably a combination of every thing, worn bearings, rockers, pump
Carl S
Member #: 1761
Stalker
This is what I thought when i first started getting issues, but then i remembered with the old oil, i would never see the oil pressure light, the briefest of flashes from the light when cold then and then never again. With the 20W50, i often see it stay on for a few seconds from cold, and for a long time on hot starts, some times 10 seconds.
The only difference in my case, is the oil type and grade.
51, pah rubbish, my old one made 52, yaaaa boo sucks.....
i currently have 20/50 comma classic stuff in, its been excellent i have tried 4 or 5 different mineral oils in this engine imo thats the best so far, but with this recent hot spell we just had i did abut 30 miles on a motorway, the temps went into the red briefly and this oil is well and truly cooked
on the other hand my last 998 had done 60k ragged over 7krpm every gear for 25k of it, i ran it on gtx magnetex no oil pressure issue but when i stripped it down i could see light down the side of the pistons and lovely clonking on all the bearings, i loved that engine it just never stopped pulling
anyway back on topic, i will buy synth / semi synth for the next change ( ie this week)
i also have a tim guage in the astra ,with the thin copper pipe ,its very slow to read too.
I would firstly bin the ball bearing release valev and fit a standard one. I had no end of trouble with odd oil pressure when I ran one.
My thought is that 40psi when running is maybe a little low, but perfectly acceptable. Slow build up can be caused by a dirty pickup filter.
Ben H
Member #: 184
Melton Mowbray, Pie Country
I seem to remember we had odd oil pressure reading on the TT. It was tracked down to the 'T' piece on the engine where the gauge pipe was taken from. We drilled out the 'T' picece and all was well.
I am sure Wil will correct me, it might have been the sensor, but the bore was definitely to small.
http://www.twin-turbo.co.uk
You are right Ben. The oil pressure signal was being taken froma T-piece that was also feeding the turbo. Because of the small bore through the T-Piece, and the flow through it the oil pressure read very low.
However, unless the regs have changed, Jim won't have a turbo fitted so there'll be no oil feed from the pressure take-off point.
Ben H
Member #: 184
Still worth a look though.
cheers guys, I'll check that. Does everyone have a simular opinion on ditching the ball?
I've heard of random oil pressure issues when using the ball setup too.
i ditched the ball too, same reason as john, one day cold fire up would be sky high, the next it would be quite low
PaulH
Member #: 2340
Dublin Ireland
ditch the ball is a bad Idea that does not work the bullet works just fine all you need do is sand the barrell of the bullet with some 120G paper to get it nice an smoth put it back in with a little engine asembly lube and bobs your uncal,
However your prbablam is shot bearings 998 dont take reving well the cranks are soft in my experence,
what are you reving this to jim
On 17th Feb, 2009 Rob H said:
not sure what it revs to, flat out in 2nd gear, no rev counter or data logging
Mine used to rev to an indicated 6500rpm or so. Valve bounce then limits RPM from any more.
Ben H
Member #: 184
my 998 revs past 7k and has done for years with no crank or oil pressure issues (that I know of)
PaulH
Member #: 2340
Dublin Ireland
was that a hardened crank ben
nope, and it's a pretty old engine now, won me the Class A cup at Avon 10 years ago, it even got re-built in Donnington park services as it had a holed piston when a valve broke (long story)
Get typing then, you can't drop a hint of an interesting tale like that, and then not tell us!
mcalvert39
Member #: 442
Manchester
Ive got a 998 with only slight mods. I have a tim gauge which takes around 3 to 5 seconds to prime from cold. Almost instant when warm.
Reads around exactly the same as yours under those conditions. Ive done 60K and have had no problems with the engine at all. Id say it was normal.
Well the car was being put back together to transport me and sooz from our wedding cereomny to the reception. The week befoer Ben was doing some testing with the then new Megasquirt, when it dropped a valve-head that stuck in the piston. Knowing that we needed it the next week Ben stripped it all down and I got a piston and rod. We then met at Donnington Park services (about mid way between our rhouses at the time) where we rebuilt the engine in the boot of his car.
Car ran fine at the wedding and is still going strong.
ahhhhh and they all lived happily ever after. *happy*
