Home > Help Needed / General Tech Chat > Is this now F@~ked....?
Si P
Member #: 912
North Yorkshire
Right gents I've just started a strip down and refresh of a head I had sat on the shelf. And found this small crack in the valve seat.
Is it now scrap...? or can it be saved.?
Si (with fingers crossed.)
AWDmoke
Member #: 713
Western Australia
As long as it's just the seat & not the head it'll be fine. Just get new seats put in.
On 24th Dec, 2008 Nic said:
evolotion
Member #: 83
Glasgow, Scotland
that isnt a hardened seat, crack is in the head..
Denis O'Brien.
Richie
Member #: 628
as above, i have had issues with Longman heads doing this but only with dinner plate sized valves put in.......
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
retroracer1380
Member #: 1972
Worcester
I have used heads with cracks here before and have had no problems
I would NEVER use the head as it is, but if you take it to an experienced head modifyer, I guess he could tell you whether if it's scrap or not. If fitting a new seat removes the entire crack, then it'll be fine.
The problem with the very large inlet valve heads that Longman produced was that he would undercut the valve seat in the port between the two valves , so thin was the material, left that it would crack fairly quickly relatively speeking,
Ian Jonson put a brand new Longman GT 17 on his Nitrous speedster and it cracked the valve seat in about 5 runs, lol.
i did succesfully weld in up for him but he never ran that head on gas again ,
carl
what would the symptom be for a crack head??
