| Home > Help Needed / General Tech Chat > few questions | |||||||
![]() 871 Posts Member #: 2590 Post Whore Croydon |
5th Jun, 2010 at 04:13:35pm
just been having a few thoughts recently after starting the car up and driving it for a bit now and knowing everything works want to change a few things
![]() 334 Posts Member #: 7169 Gobshite that posts wank videos. Somerset, UK |
5th Jun, 2010 at 05:08:58pm
what boost are you running?
Gaball said:
Motorsport Engineering Student Project Car 1293 Turbo Mini (on a student budget) On 7th Oct, 2010 apbellamy said:
Carbon but plug? |
5th Jun, 2010 at 05:10:26pm
i have got 5 psi but what is the usual max psi and power? for my setup |
5th Jun, 2010 at 05:13:33pm
i dnt know what the T3s can run but 5psi seems rather low to me?
Carbon but plug? |
5th Jun, 2010 at 05:20:40pm
i have the standard mg N/A cam |
5th Jun, 2010 at 05:26:53pm
ok,
Carbon but plug? |
5th Jun, 2010 at 05:28:13pm
would the gearbox etc standard for 14psi as its all the standard metro N/A stuff |
5th Jun, 2010 at 05:32:05pm
depends how you drive it,
Carbon but plug? |
5th Jun, 2010 at 05:33:23pm
if its all standard stuff with no intercooler dont be tempted to pass 8psi of boosrt or it will end in tears
5th Jun, 2010 at 05:34:08pm
today i will be taking the carb and manifold and turbo off and hopefully try do some porting on some of the parts, just seen on youtube and it looks easy :S
5th Jun, 2010 at 05:36:14pm
he is running an inter cooler so i thought 10psi would be ok...
Carbon but plug? |
5th Jun, 2010 at 05:36:57pm
There's more to porting a head than just hacking away & making the ports bigger. I'd suggest having a good read of Vizards big yellow book to get an idea of the basics. |
5th Jun, 2010 at 05:37:32pm
140bhp is very feasable if everythings done correctly, however might want to look at getting interal components strengthened or maybe im being to cautious with mine Gaball said:
Carbon but plug? |
5th Jun, 2010 at 05:50:03pm
was plannin on porting the head last or having you do that |
5th Jun, 2010 at 06:03:13pm
Yes the elbow's pretty straight forward if you've got a decent grinder. :) |
5th Jun, 2010 at 07:17:58pm
i was after using a drill with a metal burr attached is this ok? |
5th Jun, 2010 at 07:33:13pm
On 5th Jun, 2010 blister said:
i was after using a drill with a metal burr attached is this ok? you would be there all day but doable
Yes i moved to the darkside |
