Home > Help Needed / General Tech Chat > Oil catch tank/can
MrOz
Member #: 5007
Crazyhill, Livi
Having done a search on the above topic, I've got a couple of questions about making best use of an oil catch tank.
All the threads I've read over seem to say it's a good idea, so.....
Anyone got recommendations for the best size to use, or is it a matter of whatever can be fitted?
Also, would it be a good idea to have a take-off fitted to the rocker cover - I've only got one breather on the clutch housing btw.
Roughly how often do you have to empty them?
I've been venting the remaining breather to atmosphere using a K&N filter, but it appears that the engine bay is getting covered in oil mist and I guess this will be getting drawn in to the inlet.
Oz
"se ne estas rompita, ne ripar ĝi - supercharge ĝi."
maccamcvey
Member #: 6673
Worral Sheffield
I have heard (no first hand experience) the more breathers the better and have 3 on my new engine, clutch, rocker cover and timing chain. all going into a 750mm alloy bottle with a breather on top.
MrOz
Member #: 5007
Crazyhill, Livi
Yeah, that's what I took from reading the threads, think I'll see about getting a take off for the rocker - might also have a look at how to get a take off back on the timing cover.
