Home > Help Needed / General Tech Chat > Hole in my clutch cover but dont know why??
MiniVanMan
Member #: 5262
Yeovil, Somerset
Hey again guys,
Ive got a hole about an 1"ish in diameter with a smaller hole on each side in my clutch/flywheel casing but i dont know why??
(I cant seem to upload pics so il describe best i can)
As you look at the front of the engine, its directly behind the starter motor (pre engaged), in the alloy casing that bolts onto the block (that covers the flywheel etc...).. Its got the 1" hole then a smaller hole above & below it.....
its a proper turbo unit from a '85ish metro i believe
Do you guys know What the hell its for?? *oh well*
some people drill them to help cool the clutch
MiniVanMan
Member #: 5262
Yeovil, Somerset
oh right, it just looks abit too professionaly done to be cooling (but the other part of the casing has been drilled)
Nothings going to jump or fall out if i leave it open is it?
manifold
Member #: 1734
Lancaster
timing mark cover?
Turbo Shed
Member #: 30
Epsom, Surrey
timming hole
Its the hole to check the timing.
MiniVanMan
Member #: 5262
Yeovil, Somerset
oh right, so is there meant to be some kind of cover? or is it just meant to be open?
Mine wasn't drilled in the centre so didn't have a cover. It will be fine left open, just don't drop anything down the hole! lol
Is it the hole about at about 8 O clock on this photo?
graemec
Member #: 1424
Carnforth, Lancs
I think you're all barking up the wrong tree! The timing mark hole isn't behind the starter nor in the casing that bolts to the block.
Sounds to me like some type of sensor off the flywheel - didn't the MPi have something working off a reluctror ring in the flywheel/clutch assembly?
Asphalt
Member #: 1027
Germini, black forrest
Exactely! SPI and MPI have the flywheel sensor behind the starter motor. Obviously of no need when runing a carb. Some people leave it open, I made little cover for it when converting from 'i' to carb.
This one: http://img40.imageshack.us/img40/487/75164382.jpg
Edited by Asphalt on 7th Jun, 2010.
[X] nail here for new monitor
it could be the drop gear's breather take-off the spi trigger sensor is not 1" in dia..
Ah yeah just re-read the description, sounds like the breather hole.
matty did you do that with a 12 gauge shotgun??
lol
From the description of being behind the starter it sounds like the injectio crank sensor hole to me. Probably won't do any harm left open, or block it off if you like.
MiniVanMan
Member #: 5262
Yeovil, Somerset
Cheers guys, il make a little cover to go over it just to be on the safe side :)
Thanks youguys are well helpfull!!!
turbo hogster
Member #: 178
stowmaket suffolk
some of them had this hole with a rbber bung in it
