| Home > Help Needed / General Tech Chat > coolant plumbing | |||||||
492 Posts Member #: 3684 Senior Member wisborough green west sussex |
8th Jun, 2010 at 06:37:56pm
Right i have just run my new engine for the first time yesterday and it seems to get hot very quickly so i fear i have plumbed it incorrectly. I have tried searching but nothing reali helps in my case.
8th Jun, 2010 at 06:57:59pm
have you drilled any holes around the flange of the thermostat? On 26th Oct, 2004 TurboDave16v said:
8th Jun, 2010 at 07:03:43pm
Do you have a piccy.
8th Jun, 2010 at 08:11:13pm
Sprocket...
8th Jun, 2010 at 08:15:49pm
The small bit that comes of the thermostat housing should be routed to the expansion tank. Where is your expansion tank? It should be the highest point. On 11th Feb, 2015 robert said:
8th Jun, 2010 at 08:18:06pm
sorry pic not great expansion tank is inside passenger wheel arch you can just see in pic... |
8th Jun, 2010 at 08:23:51pm
Heres another side view pic with tank. |
8th Jun, 2010 at 08:25:31pm
looks a bit low to me, needs to be the highest point in your system. On 11th Feb, 2015 robert said:
8th Jun, 2010 at 08:26:56pm
right thanks i will raise it then though i still think i have it plumbed wrong |
8th Jun, 2010 at 08:30:47pm
As Andy says, expansion tank should be the highest point in the system - vapour (ie, steam) rises.
8th Jun, 2010 at 08:37:26pm
noted i will raise right up first thing, i still feel i have it wrong though |
8th Jun, 2010 at 08:51:58pm
Can you do a sketch and scan it to post as a picture of where you have run each pipe to and from ??? Schrödinger's cat - so which one am I ??? |
8th Jun, 2010 at 09:08:43pm
hope this is ok rough 2 minute job blue being the pipes, then head manifold rad and expansion tank. |
8th Jun, 2010 at 09:13:32pm
Not 100% clear but if the bottom of the expansion tank goes in to the top of the radiator..... wrong......
8th Jun, 2010 at 09:43:02pm
If there is no flow over the thermostat, it will open late.
8th Jun, 2010 at 10:07:58pm
right ok think im with you thanks for your help, think i might get some one who knows what there doing to sort it as i dont want to melt my engine!!! |
8th Jun, 2010 at 10:30:22pm
Am i right in saying this is what your thinking??? |
8th Jun, 2010 at 10:36:43pm
heres how i see it ........... dump the metro stat housing and just use the original mini one, hose straight to the the top of the rad
![]() 392 Posts Member #: 5702 Senior Member Cornwall |
9th Jun, 2010 at 09:32:12am
Is this what you describe?
9th Jun, 2010 at 11:02:31am
plumbing it wrong will give you trouble but so will having a side mounted rad and a flip front (no inner wings) on the standard mini set up the inner wing makes a massive difference. a friend of mine had a standard set up and no inner wings and found as soon as he stopped the temp climed rapidly into the red.
9th Jun, 2010 at 04:48:08pm
right thanks again, Steve i think ill go with what you have described thanks and yes haimesyboi i believe your pic is what steve has written...
![]() 730 Posts Member #: 1791 Post Whore Cranleigh, surrey |
9th Jun, 2010 at 04:54:03pm
I do indeed, although sold mine recently so would have nothing to reference against.
"Cars are a lifetime of pain" |
