| Home > Technical Chat > Help me with the engine for my Offroad Buggy! | |||||||
![]() 39 Posts Member #: 8850 Member |
9th Jun, 2010 at 01:25:21pm
Hi guys, right, this isnt Mini based in the slightest, but i respect the amount of knowledge you guys have on here so i thought it was a better place to ask then on the offroad forums full of pikeys!
Edited by Rich. on 9th Jun, 2010. |
![]() 453 Posts Member #: 6449 Senior Member Brisbane, Australia |
9th Jun, 2010 at 01:34:26pm
Have you thought about dropping your gears down? I think you can get reduction transfer case gears for sierras with something like a 60% reduction in low range. Not sure if theres something similar. In boost we trust |
9th Jun, 2010 at 01:43:01pm
Sorry, should have added that, im tunning twin transfer box's giving me 12 forward gearsa dn 3 reverse.
9th Jun, 2010 at 01:49:11pm
i would supercharge it, na tuning will move the power up the revs and reduce low down torque, turbo would bring lag
Yes i moved to the darkside |
9th Jun, 2010 at 01:55:19pm
The only problem i have with a supercharger is that it wouldnt be very itnterchangeable in a hurry, unless i could make a bracket for it that bolted onto the tubework somewhere and took the feed of the already huge length of auxilary belt.
9th Jun, 2010 at 05:39:33pm
Surely a chevy LS2 or a vw W10 would be a wise idea?
9th Jun, 2010 at 09:01:28pm
On 9th Jun, 2010 Rich. said:
The only problem i have with a supercharger is that it wouldnt be very itnterchangeable in a hurry, unless i could make a bracket for it that bolted onto the tubework somewhere and took the feed of the already huge length of auxilary belt. In this case what type of charger would you reccomend? The Eaton M45 or is there a more suitable one? Thanks for the help Rich i would have thought it would be easyer than a turbo to swap the engine mount the supercharger close to the engine, ( directly to the inlet?) pull the whole unit out the car ( engine/charger) swap it onto the other engine and mount the lot back in the m45 boost the 1.6l bini engine quite well so should be good for yours Yes i moved to the darkside |
9th Jun, 2010 at 09:33:45pm
Awesome, that sounds perfect then!
10th Jun, 2010 at 01:11:38am
30bhp gain on 90 is 1/3 so i would look for 1/3 bar or a
Awesome, that sounds perfect then! What about lowering the CR of the engine? To get the 30 or so horsies of boost im looking for what sort of pressure do i need to be running from the charger? And would this warrent getting some headwork done? Thanks for the help Rich Yes i moved to the darkside |
![]() 1137 Posts Member #: 1450 Post Whore Near Paris - France |
10th Jun, 2010 at 03:40:47am
What are the rolling conditions ?
Rusty by nature
They said "That sounds rough mate." I said "Cheers it cost me a fortune to make it sound like that!" |
10th Jun, 2010 at 09:30:24am
I agree, its going to be a compromise, but then again i will have alot more gear options than the other competitors, therefore i can selecr my revband for a given obstcal more easily.
520 Posts Member #: 2093 Post Whore Grenoble, France |
10th Jun, 2010 at 01:36:52pm
I think in this kind of machines you want a low end torque. If you make a high revving engine you will loose torque.
Edited by alpa on 10th Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
10th Jun, 2010 at 02:08:15pm
Well looking at some specs it would appear the compression ratio is 8.90:1.
10th Jun, 2010 at 02:15:05pm
Well apparently someones done it before!
10th Jun, 2010 at 03:23:31pm
If you want 120 or even 160hp from a jap engine don't bother with modifying it, just bolt the turbo and it will work. I was pretty sure the CR is low, it's common on 4x4 japs.
10th Jun, 2010 at 05:21:39pm
That sounds perfect then!
11th Jun, 2010 at 07:50:11am
You'll probably have to use something is place of SPI. Carbs + turbo is a special subject, make a search.
Edited by alpa on 11th Jun, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
11th Jun, 2010 at 11:53:55am
Thats brilliant, thanks for the help mate!
3596 Posts Member #: 655 Post Whore Northern Ireland |
11th Jun, 2010 at 07:54:08pm
What about a basic VW tdi engine ?
12th Jun, 2010 at 11:04:35am
Well thats the thing, with the amount of gears the specifics requirements of the engine arnt quite so bad, i can just use the gears to find the power band of the engine.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
12th Jun, 2010 at 11:12:58am
i have no input atall.
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
12th Jun, 2010 at 03:55:33pm
Of my insperation Rig? I have plenty of it, its awesome isnt it!
12th Jun, 2010 at 03:56:13pm
Thats only running a little 1.3, although the tyres are 9" smaller than what im going to be running. |
12th Jun, 2010 at 04:00:58pm
Id be leaning towards running it as a 1.6 with injection. More trickery and things to go wrong, but it wont die on you if it gets too angled.
In boost we trust |
