Home > Help Needed / General Tech Chat > Twin HS4's
Rich_2137
Member #: 8945
Nottingham
Hi
Anyone know a good starting point on the setup on my Twin HS4's, needle, spring, and how far to take the adjuster out etc??
Thanks
Rich
Edited by Rich_2137 on 9th Jun, 2010.
pinkyandnobrain
Member #: 2588
Pretoria South Africa
Well, what is the spec of the engine ?
"Try to take over the world!"
Rich_2137
Member #: 8945
Nottingham
Hi
Yeah sorry about that the spec is
1380cc block
MD 286 cam
SF4 slark head 31mm exhaust 36mm inlet valves ported and polished
Wedged and balanced crank
GT con rods, Balanced
1.5 lift roller rockers
lightened steel flywheel
steel back plate
orange clutch
Straight cut drops
Recon box with cross pin diff and center oil pick up
3:1 FD
Megajolt ignition system
Thats all i can think of, hope it helps *oh well*
Thanks
Rich
