Home > Wanted > COOPER S ROD 1
hi gents well iam after ONE S rod, only one, compleate with bottom cap
iam sure someone will have one only, i have a set of three
iam sorting myself an intresting! engine for the near future *wink*
ANYONE ?
any way to tell them apart? I have some pre a plus rods going spare, just not sure which ones they are
I've got one lightened Longman Rod, with a bush for 18mm wrist pins. Of any use?
smaller big end i think andy
Steve ,how the fark can you have a set of three, they come in sets of four,lol.
I wonder if Wolfie has any useable ones left he would part with after his destroyed engine?
well had a good root around i have 3 rods and only 2 caps, carl, richi on this forum gave me them some time back he must! have thrown a rod at some time.
Vegard thanks for the offer but i need standard rods not worked
andy they are cast in the beam part number ..... AEG625
i need 2 rods compleate with caps ANYONE ?
Edited by BENROSS on 10th Jun, 2010.
Mine are 12G1507 which I think are standard pre a+ 1275 rods.
Prawn
Member #: 5232
basingstoke
Steve, AEG 625's are not S rods, they're midget rods.
S rods are AEG 521, and are much heavier than the 625's. I'm running worked 625's in my current engine, although I've got a set of 3 mint 521 S rods from an engine which span 1 shell if they're of any use to you.
I was going to ebay them off one by one.....
They are standard Pre-A+ rods Andy
Edited by John on 10th Jun, 2010.
i have a set of 4 that come with arp fastners, however 2 will need to have big inds checked for roundness as they did get hot
AH! iam cought between the devil and deep blue sea here
i realy need 2 AEG 625s midget rods then thanks for the correction prawn
wolfie pm me with a price buddy
prawn S rods only 3 pitty i havent the other one many thanks
Prawn
Member #: 5232
basingstoke
yea, annoyingly, 3 are mint, one span a shell and it's damaged the race on the rod
there is midget rods on ebay atm
innocenty?? dont know the difference
http://cgi.ebay.co.uk/Mini-Inochenti-Coope...=item35a9ef580c
aeg625's
http://cgi.ebay.co.uk/MG-Midget-con-rods-A...=item20b166f373
Allegedly the inno rods are made from the same material as the S rods but with a normal sized big end.
prawn, i have had a look in the bowels of the workshop and i have 2 midget rods AEG625 and have found one S rod
AEG 521 but ..... with no btm cap
is the btm cap ok on the S rods 521 on the one that spun ?
if so iam intrested prawn
or i need 2 AGE 526 RODS midget rods
Not quite. The S rods are from EN21. The Inno/1300GT rods are made from EN19 which is the same as the 625 rods which are NOT S. They are Midget rods.
Cheers V. You should start a website, something like Vega-pedia.com :)
vegard what grade meterial is the A
+ rod made from ?
PaulH
Member #: 2340
Dublin Ireland
steve I have just what your after I have two perfect 625 sitting on my desk,
PM me your address and Ill work out a price posted to you,
regards,
Paul.
On 17th Feb, 2009 Rob H said:
+ rod made from ?
A- EN16
A+ -EN15
Peda (allthough possibly not with that spelling) means child John, probably not the best web site name you could have come up with...
+ rod made from ?
A- EN16
A+ -EN15
So if I was having a set of rods worked, which would be the better rod to pick?
pm sent paul
