| Home > General Chat > Who said ball type wheelbearings have less friction? | |||||||
9th Jun, 2010 at 07:12:08pm
Just built up a front hub with taper roller bearing torqued at 100lb ft with LM grease and another with ball type bearing torqued at 35 lb ft with Redline CV2 grease.
Edited by paul wiginton on 9th Jun, 2010. I seriously doubt it! |
9th Jun, 2010 at 07:15:38pm
The one you get the grease out of and put oil in
9th Jun, 2010 at 07:15:44pm
9th Jun, 2010 at 07:19:28pm
On 9th Jun, 2010 mini13 said:
rear hubs? Front Edited by paul wiginton on 9th Jun, 2010. I seriously doubt it! |
204 Posts Member #: 5022 Senior Member Oxford, Kings Lynn, Pod, Pub. |
9th Jun, 2010 at 07:43:03pm
Redline CV2 grease is very sticky from memory for a fair test you should use the same grease for comparison
Got A GTM With A Honda In the Back, and huge Nitrous bottle where the passenger seat should be when racing!
On 19th Oct, 2009 Nic said:
Ill donate to the cause if you can make it do wheelies!! |
9th Jun, 2010 at 07:44:24pm
On 9th Jun, 2010 SidewaysGTM said:
Redline CV2 grease is very sticky from memory for a fair test you should use the same grease for comparison West I was lead to believe the CV2 should be slippier I seriously doubt it! |
9th Jun, 2010 at 09:13:50pm
Mr Austin probably uses KY Jelly 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
9th Jun, 2010 at 09:29:01pm
On 9th Jun, 2010 paul wiginton said:
Who said ball type wheelbearings had less friction? You did. I distinctly remember it over a cup of tea in your garage, even the wife went out and bought some for her Fiat after she heard! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Jun, 2010 at 09:35:10pm
Who said ball type wheelbearings had less friction? You did. I distinctly remember it over a cup of tea in your garage, even the wife went out and bought some for her Fiat after she heard! Some twat told me though Edit; Actually it might have been Calver Edited by paul wiginton on 9th Jun, 2010. I seriously doubt it! |
9th Jun, 2010 at 09:55:53pm
Who said ball type wheelbearings had less friction? You did. I distinctly remember it over a cup of tea in your garage, even the wife went out and bought some for her Fiat after she heard! Some twat told me though Edit; Actually it might have been Calver Well he is a twat! Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Jun, 2010 at 10:32:12pm
Just built up a front hub with taper roller bearing torqued at 100lb ft with LM grease and another with ball type bearing torqued at 35 lb ft with Redline CV2 grease. Which one should be easier to turn? Paul Torque used is irrelevant. The taper at that torque will have a spacer in the middle, hence so tight. Tapers with no spacer are literally just nipped up. I'd say taper bearing easier to turn. 9.85 @ 145mph
9th Jun, 2010 at 10:34:46pm
Where do you get the 100ftlb and 35ftlb values from? On 26th Oct, 2004 TurboDave16v said:
![]() 690 Posts Member #: 1851 Post Whore Woolavington, Zummerzet |
9th Jun, 2010 at 11:59:58pm
I thought the torque setting for a ball bearing hub was 60lb/ft - it was last week when I did a pair of drum hubs.
Metric is for people who can't do fractions. |
10th Jun, 2010 at 06:06:20am
If I torqued the ball to 60 lb it would hardly turn, 30-35 it would. The 100lb for the taper is all I could generate holding it in a vice before it started to slip. I seriously doubt it! |
784 Posts Member #: 912 Post Whore North Yorkshire |
10th Jun, 2010 at 08:45:38am
Does the grease not start to become fluid until its up to working temp..?
Edited by Si P on 10th Jun, 2010. I drill holes in everything..! |
10th Jun, 2010 at 05:21:24pm
Whats a Metro torque setting out of curiosity? they have balls as standard I seriously doubt it! |
10th Jun, 2010 at 05:21:44pm
Grease is basicaly oil with thickners such as clay or chalk (the most simplest of grease). The thickners prevent the oil squeezing out of the bearings at supersonic speeds On 26th Oct, 2004 TurboDave16v said:
10th Jun, 2010 at 06:02:52pm
On 10th Jun, 2010 paul wiginton said:
Whats a Metro torque setting out of curiosity? they have balls as standard The red book of lies says 75lbft On 11th Feb, 2015 robert said:
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
10th Jun, 2010 at 06:10:22pm
On 10th Jun, 2010 Sprocket said:
Grease is basicaly oil with thickners such as clay or chalk (the most simplest of grease). The thickners prevent the oil squeezing out of the bearings at supersonic speeds ![]() but wouldnt it then sound like a straighcut gearbox if it was going supersonic? ![]()
David. |
10th Jun, 2010 at 06:18:55pm
Grease is basicaly oil with thickners such as clay or chalk (the most simplest of grease). The thickners prevent the oil squeezing out of the bearings at supersonic speeds ![]() but wouldnt it then sound like a straighcut gearbox if it was going supersonic? ![]() ![]() No because like I said, the thickners 'prevent' the grease squeezing out at supersonic speed. In other words, it never reaches supersonic speed, therefore, cannot sound like straight cut gears
10th Jun, 2010 at 06:24:46pm
ah of course, perhaps ill read next time :p should start telling people to put oil into their bearings if they want the noise for cheap haha David. |
![]() 553 Posts Member #: 1356 Post Whore TRURO, CORNWALL |
10th Jun, 2010 at 08:30:02pm
On 9th Jun, 2010 wil_h said: On 9th Jun, 2010 paul wiginton said:
Who said ball type wheelbearings had less friction? Didn't Richard Longman say in some article that he used these type of bearings in his Clubman touring car as they had less drag? Edited by dazibee on 10th Jun, 2010. |
10th Jun, 2010 at 08:56:29pm
Who said ball type wheelbearings had less friction? Didn't Richard Longman say in some article that he used these type of bearings in his Clubman touring car as they had less drag? And guaging from his success he is not a twat I seriously doubt it! |
12th Jun, 2010 at 02:29:28pm
Been doing lots of experimenting with different bearings, different greases, different amounts of grease and oil, plus reading up on KAD hubs where the shoulder inside the hub is wider so that the bearings are no longer pre loaded.
12th Jun, 2010 at 04:18:40pm
the shoulder would need to be narrower to reduce the preload,
, id say roller, but i doubt the difference will be huge.
