| Home > Technical Chat > N/A engine spec, need opinions/suggestions | |||||||
157 Posts Member #: 6496 Advanced Member Somerset |
9th Jun, 2010 at 09:37:11pm
Well after nagging Paul W for the last hour I think i've come up with an engine spec i'm happy with.
Edited by Owen on 10th Jun, 2010. On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
9th Jun, 2010 at 09:39:02pm
I think you've made a wiser choice with the cam than the 320 you said you were going to use.
9th Jun, 2010 at 09:48:35pm
Just a thought, would it not be better to go for say a 286 ? Will you see anymore power using a 296 when you're surely going to have to set your rev limit to something fairly sensible when using a long stroke crank ? |
9th Jun, 2010 at 09:52:06pm
Speak to Swifty - he is advertising a stage 3 LCB now I seriously doubt it! |
9th Jun, 2010 at 09:56:16pm
I'm not sure, the 1380 I had (was borrowing off a mate) had a 286 and it was a sheer let down.
On 9th Jun, 2010 Turbo Phil said:
Just a thought, would it not be better to go for say a 286 ? Will you see anymore power using a 296 when you're surely going to have to set your rev limit to something fairly sensible when using a long stroke crank ? Edited by Owen on 9th Jun, 2010. On 9th Feb, 2010 joeybaby83 said:
1391 Posts Member #: 1686 Post Whore Oxford |
9th Jun, 2010 at 10:03:41pm
It run out of puff at around 6500 revs in a 1293. Certainly came in at the time they specify though mind.
Edited by Sam on 9th Jun, 2010. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
10th Jun, 2010 at 08:45:40am
296 will work great with that spec, make sure you keep good swirl in combustion chambers, compression is spot on use a little cvl in each tank to get the best from it run water temp at 80 deg set the cam in. At 104 and use .018' valve clearances at it should pull well over 120 bannas On 17th Feb, 2009 Rob H said:
10th Jun, 2010 at 08:57:42am
86X73,5 is 1460cc On 13th Jul, 2012 Ben H said:
10th Jun, 2010 at 09:09:49am
If you want to compete in sprints then you'll need to stick to under 1400, otherwise you'll not be elligable for anything. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
10th Jun, 2010 at 04:51:06pm
Sorry V, I meant 84mm. Edited now.
10th Jun, 2010 at 05:00:58pm
Also:
10th Jun, 2010 at 05:08:59pm
Scatter.
