| Home > General Chat > O/T - Ford Main Agents | |||||||
10th Jun, 2010 at 09:51:04pm
Total rant I'm afraid.
549 Posts Member #: 5327 Post Whore Dudley, West mids |
10th Jun, 2010 at 10:01:08pm
My old man's got a 55 plate focus. At the last MOT the rear wheel bearing had failed. It was just out of the warranty period. The price ford wanted was around £280 (if I remember correctly). I told him 'bollocks to that' and brought a brand new rear hub/bearing for £90 and fitted it in half an hour. Apparently ford had a problem with wheel bearings on the mk2 focus and there is loads of stuff about it on the net. |
10th Jun, 2010 at 11:19:47pm
i rearly use stealers, last time i did brakes and pads on my audi it came to like £55 or something using OEM spec brembo discs and a german make pads Crystal Sound Audio said:
11th Jun, 2010 at 12:01:52am
Im with wolfie, i always use a good reputable local shop. And if you know the right ones some have proper stamps On 10th Jun, 2010 wolfie said:
i rearly use stealers, last time i did brakes and pads on my audi it came to like £55 or something using OEM spec brembo discs and a german make pads 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Jun, 2010 at 07:52:35am
The heater knob has fallen off the wifes Abarth (less than 6 months old). so I phoned up the garage to get it sorted. They wouldn't just order the part they wanted me to take it in so they could look at it and then I could take it again to get fitted.
11th Jun, 2010 at 08:44:03am
On the car brake lathe would be a cheaper solution - there is no way it would need hubs just a damn good clean up. Modern cars are very prone to disc distortion due to the hard pad material used these days On 5th Sep, 2011 Vegard said:
11th Jun, 2010 at 08:44:52am
11th Jun, 2010 at 08:46:35am
On 10th Jun, 2010 Rod S said:
Total rant I'm afraid. The best bit is they refused to give her an invoice for the previous - warranty - replacement as it was for "free". . They are quite right there is no obligation to - sorry! On 5th Sep, 2011 Vegard said:
11th Jun, 2010 at 08:52:33am
Dealers are a joke. I don't know if it just Ford or if they are all the same.
11th Jun, 2010 at 09:45:01am
i'd be surpirsed if most of the spanner wankers in a main dealer were able to measure if the drive flange was running out of true (hope i'm not offending anyone!)
115 Posts Member #: 2830 Advanced Member Costa del Northern Ireland :) |
11th Jun, 2010 at 10:12:49am
A couple of years ago I bought a ford puma 1.7 from a ford dealer second hand which had a few faults which I pointed out on the test drive
That mini is determined to Kill me!!!! |
11th Jun, 2010 at 10:20:08am
did you sniff it after?
On 11th Jun, 2010 wil_h said:
she dropped it right down her top, haha. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
11th Jun, 2010 at 02:00:37pm
Total rant I'm afraid. The best bit is they refused to give her an invoice for the previous - warranty - replacement as it was for "free". . They are quite right there is no obligation to - sorry! I'm sure you're right as they will say they were replaced for free under their own warranty conditions rather than Sale of Goods Act requirements, so I've written to them asking if items they supply "free" are exempt from the Sale of Goods Act with respect to merchantable quality etc... I may get no-where but writing the letter made me feel better.
I've just ordered a new pair of discs and pads, non genuine but then I wouldn't want Ford ones with two quick failures in succession. From the Ford TIS manual it looks like the setup is the same as every other Ford I've worked on, wheel off, two caliper bolts, two clips on the wheel studs and disc in your hand, 15 minutes per side maximum. And I do know how to use a DTI on the flange whereas Ford obviously don't........ Schrödinger's cat - so which one am I ??? |
14th Jun, 2010 at 08:25:20pm
Sale of goods act irrelevant you did not pay for the repair! Also any new car manufacturer can elect to repair your car under their warranty using recon parts! Even if the car hasn't been registered! On 5th Sep, 2011 Vegard said:
