| Home > Help Needed / General Tech Chat > URGENT HELP NEEDED! | |||||||
![]() 281 Posts Member #: 441 Senior Member |
3rd Feb, 2005 at 09:19:38pm
Ok,just went to start my 1275 turbo up after putting it in the mini,when doing so petrol shot out of the anti run on valve,all spark plugs were wet,spun it over without the plugs and petrol shot out,more than what should be in there.so i need to sort this out as i dont want it to fill up again and bend con rods etc! lucky we stopped spinning it over,any help much appreciated! |
3rd Feb, 2005 at 09:28:26pm
sounds like the floats stuck to me. shit in the carb prob.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
3rd Feb, 2005 at 09:29:52pm
we cleaned the carb ot before we put it in though,me dad rekons it could be needle valve?
3rd Feb, 2005 at 09:33:25pm
could be fuel pressure.. if you havn't set it..
3rd Feb, 2005 at 09:33:28pm
its spinning over and its gota spark,i hate it when things like this happens,never easy is it |
3rd Feb, 2005 at 09:34:46pm
well the metro engine came complete with the regulator attached,so we havent tampered with it and was guessing it would be set the same.....weve put 8mm feed and return. what you reckon? |
3rd Feb, 2005 at 09:35:27pm
if it still floods with the pump off then you know it's the carb and not the pressure. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
3rd Feb, 2005 at 09:39:09pm
yeah we tried disconnecting the pump (spi tank) and it wasnt having it, so your sayin its more likely the carb, needle valve or sticky float? |
3rd Feb, 2005 at 10:15:00pm
i hope you have piped the carb up correctley?
Edited by BENROSS on 3rd Feb, 2005.
244 Posts Member #: 34 Senior Member |
3rd Feb, 2005 at 11:10:53pm
Also make sure the return pipe is not blocked or kinked along its length, as it can change the fuel pressure dramaticaly. |
4th Feb, 2005 at 02:20:56pm
aha i was just looking at a pic on the net (im at work) and ive noticed ive connected the carb up wrong,looking at the carb from the front - ive blocked up the one thats coming out at an angle pointing upwards, and ive blocked the one where the carb meets the inlet manifold, is this why its doing it???
4th Feb, 2005 at 03:04:37pm
DOH!
4th Feb, 2005 at 03:06:44pm
hehe dya reckon thats whats the problem? |
4th Feb, 2005 at 03:18:47pm
Yep, you are just filling everything but the float blow.
4th Feb, 2005 at 03:20:45pm
good man you have sussed it
4th Feb, 2005 at 03:33:43pm
Cheers lads,i shall swap them over when i get home 2nite,get her started!! cant wait to hear that sweet sound of turbo and straight cut drops |
4th Feb, 2005 at 03:41:21pm
guys, just so i can learn from this....... what do these pipes do exactly AND what are the effects if you block them up like i did???
4th Feb, 2005 at 04:13:59pm
come on guys,enlighten me with your knowledge! im new to this turbo stuff |
Site Admin 6295 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
4th Feb, 2005 at 04:33:13pm
do a search, im sure there was a diagram of a carb on here not long ago. |
4th Feb, 2005 at 04:40:29pm
Good advice from everyone in this post!
Edited by turbodave16v on 4th Feb, 2005. On 17th Nov, 2014 Tom Fenton said:
4th Feb, 2005 at 04:53:27pm
That's the one i was thinking of |
4th Feb, 2005 at 10:17:55pm
Ok guys,sorted that problem,it was that little clip thats on the carb float that keeps tension on the needle valve,changed it and it runs now,
Edited by 1275_dan on 4th Feb, 2005. |
8th Feb, 2005 at 10:11:04am
check out carb connections in "how to" |
