| Home > Help Needed / General Tech Chat > which ones is the best for running 10psi? | |||||||
289 Posts Member #: 8160 Senior Member , mitcham, surrey, london, cr4 |
13th Jun, 2010 at 06:57:03pm
hi
Nothing special! |
13th Jun, 2010 at 06:59:29pm
Here is an idea, why not ring up Minispares and ask them which are the correct bolts for your standard mini metro turbo engine.
13th Jun, 2010 at 07:06:01pm
i will try to do that tomorrow, but usually I work from 8-5 without break :( and after they are close already :(
Nothing special! |
13th Jun, 2010 at 07:16:04pm
I am puzzled as to what engine you have as you have lised them all
13th Jun, 2010 at 07:36:37pm
On 13th Jun, 2010 wolfie said:
I am puzzled as to what engine you have as you have lised them all 1) A+ engine 2) mini cooper s engine 3) Bini 1.6 supercharged engine if you have a metro turbo A+ then the first and last listed will fit only hi mate i have 1.2 metro turbo engine, a+ thank you for info what is difference between S engine and A+?? Nothing special! |
13th Jun, 2010 at 07:51:24pm
number says that it is
Nothing special! |
13th Jun, 2010 at 07:58:12pm
All Metro Turbos are A+ mate. |
13th Jun, 2010 at 08:01:22pm
The best ones for running 10 psi are the ones that you already have, anything else is mental masturbation. |
13th Jun, 2010 at 08:06:13pm
On 13th Jun, 2010 Turbo Phil said:
All Metro Turbos are A+ mate. i was thinking that, but than i was confused is it or not :) thank you for help! Nothing special! |
13th Jun, 2010 at 08:10:19pm
On 13th Jun, 2010 fab said:
The best ones for running 10 psi are the ones that you already have, anything else is mental masturbation. ok, that sounds good, but i heard that you need to change them especially if they are at least 10 years old :) Moreover i have only 6 of them, but need 8, so perfectly i need to buy all set! i tried to fine standard ones but no luck :( maybe you know where to buy them??? :) Nothing special! |
13th Jun, 2010 at 08:29:49pm
these are the ones you need i think..
13th Jun, 2010 at 09:07:24pm
chominish how many did you stretch or break when you torqued them down?
Yes i moved to the darkside |
13th Jun, 2010 at 09:54:50pm
On 13th Jun, 2010 Brett said:
chominish how many did you stretch or break when you torqued them down? If you torqued them all and hence have to buy a set anyway the perfect opertunity to upgrade it was first rod, so i broke only 1 and 1 stretch. actually i am thinking to buy all set as they are probably more than 20 years old. what kind of upgrade you are talking about!! :) Nothing special! |
13th Jun, 2010 at 09:56:01pm
On 13th Jun, 2010 Nick said:
these are the ones you need i think.. http://www.minispares.com/Product.aspx?ty=...id=35000&title= not going in :( can you repeat the link please? thanks mate Nothing special! |
13th Jun, 2010 at 10:37:06pm
Minispares website was down. The links are working now. |
13th Jun, 2010 at 10:40:50pm
personally i would buy the arp for piece of mind however it seems minispares are a bit pricey compared to others for arp Crystal Sound Audio said:
13th Jun, 2010 at 10:46:35pm
yea i am thinking about them
Edited by chominsh on 13th Jun, 2010. Nothing special! |
13th Jun, 2010 at 10:51:18pm
personally i would buy the arp for piece of mind however it seems minispares are a bit pricey compared to others for arp yea, they are :( maybe you know where to buy arp little bit cheaper? :) Nothing special! |
13th Jun, 2010 at 10:59:35pm
google is your friend Crystal Sound Audio said:
13th Jun, 2010 at 11:10:08pm
Try Avonbar On 26th Oct, 2004 TurboDave16v said:
13th Jun, 2010 at 11:12:40pm
when i got some i belive minispeed were cheapest at the time. On 28th Aug, 2011 Kean said:
13th Jun, 2010 at 11:15:09pm
Infact MED are a little cheaper at £85
13th Jun, 2010 at 11:16:53pm
minispeed are £69 Crystal Sound Audio said:
13th Jun, 2010 at 11:20:10pm
Perhaps Minispeed are good for something after all On 26th Oct, 2004 TurboDave16v said:
13th Jun, 2010 at 11:22:12pm
thats if they send them
