Home > Help Needed / General Tech Chat > Atb. advice - installation help
NickG
Member #: 7912
Australia oi oi oi!
what are they like in a mini first up.
my car is a every day mini, im looking at the Quaife.
is it worth it with a mini putting out say 85ATW's?
now my 2nd question.
i do not want to take the engine out.
normally a no drama but i have Aircon * australian Hot climate*
now i have never done this before & i have been told by a old boy mechanic, who raced mini's, who has a car hoist it can be done from under the car & same as the cross pin diff.
rod change box. something along the lines of removing extractors etc & tip engine forward?
has anyone done this.
philc
Member #: 1346
bromsgrove
engine spec????
NickG
Member #: 7912
Australia oi oi oi!
it's a 1293 266 cam going to be supercharged with sc12
running a comp diff pin right now.
bene told ill get around 85atw's with all standard head
Edited by NickG on 15th Jun, 2010.
85 atw, I think that you'd get away without one. I have similar power with just a cross pin and don't feel like an ATB would help.
Can you do it without taking the engine out? depends. possibly, it would be easier if your diff housing is fitted with bolts rather than studs. The process is the same as fitting a crosspin, as you say.
Can you not get the engine out without emptying the aircon?
IMO if you have a cross pin in already, stick with that til the engine is out next.
NickG
Member #: 7912
Australia oi oi oi!
no i do not have a cross pin, but i was also looking at that as well.
im in two minds what to buy really.
doubt i can pull the engine out, with pulling all the pipes, will look again.
im thinking of getting pipes re made anyways in a neater smarter way then what rover slapped together**
i run a comp diff pin at the moment had no problems with that but i don't spin the wheels..
im kind to my little engine :)
If you don't spin the wheels or light them up under power then an ATB is more or less a waste of money for you.
NickG
Member #: 7912
Australia oi oi oi!
cool. might get a cross pin then. thanks
