| Home > Help Needed / General Tech Chat > metro turbo rebore? | |||||||
116 Posts Member #: 8367 Advanced Member bucks |
17th Jun, 2010 at 07:44:28am
hi, i am thinking of buying a metro turbo engine and i wondered if i could rebore it to 1380? would this give me much more power and would modifications would be needed apart from larger pistons?
17th Jun, 2010 at 07:50:50am
yes you could,
17th Jun, 2010 at 07:51:40am
If you are going to rebore an a series to 1380 (which is about as big as you can go) then I wouldn't waste your money on a metro turbo block. buy any old a series 1275 and use that. Go and spend 50-100 on something that needs a rebore.
17th Jun, 2010 at 11:47:39am
I strongly disagree in you logics. A Metro turbo block is just the same as any other A+ block and worth nothing.
On 17th Jun, 2010 apbellamy said:
If you are going to rebore an a series to 1380 (which is about as big as you can go) then I wouldn't waste your money on a metro turbo block. buy any old a series 1275 and use that. Go and spend 50-100 on something that needs a rebore. The only differnce in the short engine of a metro turbo are the pistons (which you obviously don't need) and in some a hardened crank. Make sure you choose a cam and head to suit your spec. On 13th Jul, 2012 Ben H said:
17th Jun, 2010 at 11:55:12am
Yep I have some 73.5mm pistons and all my blocks were STD I was very reluctant to take one straight out to 73.5mm so I have bought's Johnny's old block from this site which is currently at 73mm. Hopefully I will be able to rebore and use this, saving my standard blocks. If something is worth doing, it's worth doing half of. |
17th Jun, 2010 at 12:11:31pm
V, I was just refering to an 'A Series' as an engine type not defining that he should use an A or an A+ block On 11th Feb, 2015 robert said:
![]() 1733 Posts Member #: 1910 Post Whore Wilts |
17th Jun, 2010 at 01:18:50pm
On 17th Jun, 2010 Vegard said:
An A block however is infact worth something. Just call Swifty
the pissed up clown stood back up, did a twirl and left bollock naked, |
17th Jun, 2010 at 01:21:29pm
Call Switfy and find out If something is worth doing, it's worth doing half of. |
17th Jun, 2010 at 07:00:08pm
If you are going to rebore an a series to 1380 (which is about as big as you can go) Erm, you can get 74mm pistons for these. That makes 1399cc
17th Jun, 2010 at 07:13:35pm
On 17th Jun, 2010 Sprocket said: Come on Sprocket don't be facetious. On 17th Jun, 2010 apbellamy said: Erm, you can get 74mm pistons for these. That makes 1399cc If you are going to rebore an a series to 1380 (which is about as big as you can go) ![]()
17th Jun, 2010 at 07:22:14pm
I have one, soon to be and even better torque monster, so On 26th Oct, 2004 TurboDave16v said:
17th Jun, 2010 at 07:38:48pm
that's why I said about On 11th Feb, 2015 robert said:
17th Jun, 2010 at 09:41:42pm
the benross motor is 1380 & runs 73.5 accralite forged pistons and its not a snail .......click on the links below
17th Jun, 2010 at 11:05:00pm
There's no reliability issue with YOUR,
On 17th Jun, 2010 BENROSS said:
the benross motor is 1380 & runs 73.5 accralite forged pistons and its not a snail .......click on the links below fab, theres no reliability issues with mine yet & and its been worked VERY! hard. one thing is though john once you go that size the blocks scrap after that, it will not take another rebuild unlike if you bored it plus 20 then say plus 40 and then plus 60 though you have 3 reboars there |
18th Jun, 2010 at 07:17:43am
i'm with fab on this one
