| Home > Help Needed / General Tech Chat > Metro Turbo Clutch | |||||||
![]() 509 Posts Member #: 1027 Post Whore Germini, black forrest |
17th Jun, 2010 at 01:24:25pm
Hi!
[X] nail here for new monitor |
17th Jun, 2010 at 02:18:58pm
I was under the impression that the verto clutch was redesigned so that it operated in reverse compared to the pre-verto and as a result didn't load the thrusts up.
17th Jun, 2010 at 02:21:45pm
it puts about a third of the clamping pressure onto the thrusts, a pre verto on puts all of in on. On 28th Aug, 2011 Kean said:
17th Jun, 2010 at 06:44:10pm
Ah! That's good to know! Didn't know that yet... I see where the RTS comes from [X] nail here for new monitor |
17th Jun, 2010 at 09:34:00pm
if you want to run decent power, and we all do and you will want to (ie) over say...... 12 psi of boost ish your vertro or uprated vertro wont cut the mustard.
17th Jun, 2010 at 09:36:11pm
Try and tell Robert that On 26th Oct, 2004 TurboDave16v said:
17th Jun, 2010 at 10:07:48pm
I'm not at the 'boost it' stage yet:) I'm only going to have a play with a K 8V head :) Should be fine for that purpose?
17th Jun, 2010 at 10:37:28pm
You will be fine with a turbo clutch, the N/A engines are a little more forgiving with torque On 26th Oct, 2004 TurboDave16v said:
17th Jun, 2010 at 11:30:02pm
Now ive gone to the twin spring verto I wouldn't consider using anything else, it has a higher clamping pressure, cheaper to buy/make, easier on the thrusts and has a better feel to it. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
17th Jun, 2010 at 11:30:04pm
17th Jun, 2010 at 11:35:41pm
^^^^what he said!
19th Jun, 2010 at 05:23:56pm
I've not driven mine properly yet, but I agree with Matt and Joe. RTS all the way. I don't fancy another episode of thrust munching. In the 13's at last!.. Just |
