| Home > Help Needed / General Tech Chat > Manifold fabrication opinion | |||||||
432 Posts Member #: 7856 Senior Member Essex |
17th Jun, 2010 at 06:39:22pm
Hey, i've got so far in fabricating a manifold and would like some input before i finish welding, in the picture i need to weld beween the lines, would i be better to
157 Posts Member #: 6496 Advanced Member Somerset |
17th Jun, 2010 at 09:12:45pm
If you are using the TIG and it's a tight gap all round, just blend it in. On 9th Feb, 2010 joeybaby83 said:
yep, ball in a tube affair |
17th Jun, 2010 at 09:29:12pm
17th Jun, 2010 at 09:35:52pm
If it is a decent full penetration weld then it should be strong enough. I would not just fuse the area together without filler as this will leave it thinner and vuerable to crack in this area.
17th Jun, 2010 at 09:39:19pm
If you back purge the weld area with argon, it will keep it clean inside. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Jun, 2010 at 09:53:03pm
So basically ditch the band idea, i'll be TIG'ing it so just run it in (with filler!) and leave it alone and all will be well? I did the same on the downpipe/turbo outlet but as this is so close to the ports i thought keeping it smooth was key!
17th Jun, 2010 at 10:00:15pm
It really is worth the effort to back purge. If I want to do something quickly I stick my MIG torch inside and tape the trigger down whilst I weld round the outside as a quick and dirty solution.
17th Jun, 2010 at 10:02:04pm
I have a tee and a valve connected in the gas supply to the tig.
Edited by Paul S on 17th Jun, 2010. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
17th Jun, 2010 at 10:07:23pm
Can i use argoshield to back purge, or does it have to be pureshield? I'm now thinking i could just set-up another cylinder with a regulator and pipe straight into one of the flanges, if that would work? (mainly as i don't have the tee and i was going to do it tomorow!)
Edited by Amp on 17th Jun, 2010. |
17th Jun, 2010 at 10:10:19pm
Any gas that keeps out oxygen will do.
17th Jun, 2010 at 10:34:50pm
I'll do it properly and go and buy the right tee piece and just weld it next week, thanks very much! |
