Home > General Chat > compound boosted vag engine
since the last couple of dual boost threads recently i have been looking into it trying to figure out how the supercharger would change the compressor map requirements for the turbo
compound boosting looks fun, some trucks use it to boost over 60psi,
but found this vid and have to share it
look what they put it in *happy*
http://www.streetfire.net/video/vag-engine...urbo_206161.htm
Asphalt
Member #: 1027
Germini, black forrest
- what a noise!!
[X] nail here for new monitor
dale_hick
Member #: 7964
wakefield
brett make your own.....http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=280521805372&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en.....would look good with a nice turbo out of the back and not much exhaust :)
haha thats local too
dale_hick
Member #: 7964
wakefield
i no thought bout it myself :)
Edited by Sprocket on 17th Jun, 2010.
Asphalt
Member #: 1027
Uhmm - am I seeing thsi right? Does it have a second throttle which bypasses the supercharger when the turbo kicks in?
yeah the big throttle body infront of the turbo bypasses the supercharger when the turbo takes over it then de clutches the supercharger,
basicaly the supercharger gives it a huge kick up the arse "off boost" then when the turbo has boosted it takes over almost 600 porkies too, i love it, and im getting tempted :/
this is from the standard (eu-dm) 1.4 vw
turbo + supercharger
look at that torque 'curve/ flat line'
I had some trouble working this out when I was looking at the super-turbo route.
Basically the pressure ratio is the outlet pressure divided by the inlet presure, both in absolute terms.
Air volume flow is tricky as you have to adjust it to account for the density change. So if you have 2 bara at the compressor/blower inlet, then you have half the volume flow. But you have to account for the higher inlet temperature if it has already been compressed, so you need to apply a ratio of the actual inlet temperature divided by the compressor 'normal' inlet temperature, both in absolute terms. You need to decide if you are going to have an interstage intercooler.
Easy peasy.
Edited by Paul S on 18th Jun, 2010.
its interesting once you start looking over the calculations, id love to try it but in reality i doubt it would be for couple years if at all
im thinking about [atmos]-[turbo]-[cooler]-[charger]-[cooler]-[inlet]
there is alot of unknown efficiency thrown into the mix their i need to get my head around
is it as simple as if the supercharger boost 1bar then the turbo puts 1bar into the charger the out put is 2bar??
Edited by Brett on 18th Jun, 2010.
[atmos]-[turbo]-[cooler]-[charger]-[cooler]-[inlet] makes the most sense with the interstage cooler making the charger more effective.
The chargers, both turbo and super will work on ratios. So if you want 2 barg boost, then that could be done with each working on a 1.732:1 pressure ratio.
I have a spreadsheet of the calcs for a 200hp 998 on 2 barg boost if you would like a copy.
EDIT: got the ratio wrong.
