Home > For Sale > Lots for sale turbo, carbs, a+ head
CH007
Member #: 8863
A list of items for sale as changed plans and have a K100 head on way so won't be needing these and need to fund the other parts.
1) A+ 1275 head. Looks completely standard to my untrained eye. I cleaned with quick wire brush and run tap through spark plug threads to check nothing nasty there. came off my car as a runner. push rods can go with it if required and all rocker gear etc. £50
2) SU carb NA it's the HS4 I think but could be wrong it's 44mm anyway with complete manifold £40
3) Turbo SU carb with complete manifold. this does have a NA dash pot. (bought from Oli on here couple of weeks back all looks ok with plenum etc £60
4) T3 turbo on manifold with all relevant parts to make it run. includes elbow. seems ok without endfloat but no expert. Oli stated it had recently been removed from running vehicle with no probs. £140
I will have things like water pump etc coming up soon but need the casing for making blanking plates etc.
Also will have complete chain drive setup for cam but again just want casing for patterns at present.
CH007
Member #: 8863
I attached pics but nothing came through?
miniswordsman is looking for a turbo carb, probably worth dropping him a PM
CH007
Member #: 8863
ok will try pics again
CH007
Member #: 8863
OK turbo carn, manifold and plenum now sold.
Still have the T3 Turbo, Standard 1275 cylinder head with rocker cover complete.
Also now have a set of doors off 86 mini along with bonnet and boot as have fibreglass on the way.
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
Got a turbo carb actually, maybe I should update that.... Got it from Amp.
