| Home > Help Needed / General Tech Chat > Carb linkage problem-what is wrong/missing from my carb? | |||||||
1713 Posts Member #: 8480 MS Paint flat cap champion & Morris Ital Lover From Sheffield now live in York tha noz |
20th Jun, 2010 at 07:12:06pm
Hi all,
Edited by oli79 on 20th Jun, 2010. On 18th Oct, 2013 apbellamy said:
I am feeling particularly BACish today. On 5th Oct, 2014 Shauna said:
What that's crazy, you go commando hahaha! How heavy is your helmet ? The Morris Ital assassin! |
20th Jun, 2010 at 07:30:05pm
The abutment plate on our van is a 2 piece jobby to put the cables on opposite sides of teh carb. that looks like an n/a one to me On 11th Feb, 2015 robert said:
20th Jun, 2010 at 11:29:26pm
i done mine like the NA models you just need to file a very small amount of the carb linkage and works a treat always looking for them bigger bunches of bannanas |
20th Jun, 2010 at 11:34:27pm
oh and use the na linkage thats what i ment always looking for them bigger bunches of bannanas |
21st Jun, 2010 at 07:58:23am
yeah you have the na carb plate thingy Yes i moved to the darkside |
21st Jun, 2010 at 08:27:31pm
Right-thanks everyone for the help, decided it would be easiest just to make an additonal throttle arm, so out with the cardboard and needle files and after a failed attempt:-
21st Jun, 2010 at 08:41:19pm
my braket + throttle cam arm is on the other (proper) side, my choke is here Edited by Brett on 21st Jun, 2010. Yes i moved to the darkside |
21st Jun, 2010 at 08:51:07pm
![]() Thanks, think I will do that with the choke as it should be smoother than on the bracket, plus I havent got the little spring clip thingy! Its really odd though, been in garage for hours and never noticed that red line before!
cheers oli Edited by oli79 on 21st Jun, 2010. On 18th Oct, 2013 apbellamy said:
21st Jun, 2010 at 08:55:25pm
if you drill something like a 3mm hole ( wide enough for the cable), then a 6 mm hole but not all the way through ( for the black sleeving) it all holds it self into place Yes i moved to the darkside |
