Home > Help Needed / General Tech Chat > inertia to pre engaged starter wiring
matt-atude
Member #: 8913
seaford, east sussex
hi all, i have a inertia style wiring loom and a engine with a pre engaged starter and solonoid, i previously used the remote solonoid as a junction box however i want to do away with this as its abit of a bodge. i know the the pre engaged starter uses a 30 amp relay, my question is has anyone converted the wire loom from inertia to pre engaged? if so have you any photos of links to wire diagrams?
cheers
matt
Yes, but no diagram as it's quite straightforward.
As you say, you simply need a standard 30A relay to control the current to the solenoid on top of the pre-engaged starter.
Move the big battery cable and all the large brown wires from the lug on the wing solenoid over to the lug on the starter solendoid (you may have to extend some of them to reach).
Mount your relay wherever suits you and on the operating coil side, feed it (tag86) with the red/white wire that used to operate the wing solenoid and make sure the other side of the operating coil (tag85) goes to a good earth point (the wing solenoid was earthed through its mounting bolts so doesn't have an equivilant wire).
NB, tag85 and tag86 can be either way around, its only a coil.
On the 30A switched side of the relay (tag30) take a feed either from the 12V high current connections on the fusebox after the fuse or take it straight from the lug on the solenoid but through an in-line fuse. Other side of the relay contacts (tag87), straight to the large tag on the solenoid. Make sure these wires are rated 30A (same size as the main brown wires) and it is a 3/8 lucar connector on the solenoid.
Finally, if your wing solenoid also had a yellow/white or yellow/black wire that you can trace back up to the coil - which means you have a ballast ignition system - take this to the small 1/4" tag on the new solenoid, it is the equivilant ballast bypass contact.
EDIT - standard relay tag numbers added.
Edited by Rod S on 22nd Jun, 2010.
matt-atude
Member #: 8913
brilliant, thats exactly what i wanted to know cheers
matt
mcalvert39
Member #: 442
Manchester
Sorry to hyjack but is their a difference in both ring gears from interia and pre engaged?
Ive got a flywheel that i want to use on my new engine but its from an inertia setup and my new one has a pre engaged starter.
Yes,
Number of teeth are different and the angle and lead-in shape and distance from pinion is different.
Most important is number of teeth - can't remember of the top of my head but do a search, it's been quoted many times before.
109 and 127 iirc
