| Home > Help Needed / General Tech Chat > std blower set up and pc fans | |||||||
![]() 2054 Posts Member #: 452 Post Whore Chester, UK |
22nd Jun, 2010 at 08:17:17pm
bit of an odd question i'm ditching the blower in the mini and replacing with a custom set up but can anyone help with the cfm rating of the normal assembly is as i've no idea what to aim for :/ Edited by t@z on 22nd Jun, 2010. |
22nd Jun, 2010 at 10:10:57pm
PC Fans
22nd Jun, 2010 at 10:12:04pm
yep PC fans are poo for cooling a rad |
22nd Jun, 2010 at 10:41:31pm
rad? i meant blower in the car ie screen demister etc |
22nd Jun, 2010 at 10:51:11pm
im not sure you would feel much air movement, i think they work best when directly next to what you are trying to cool. |
22nd Jun, 2010 at 10:55:13pm
A PC radial fan is not the same as a forward curved centrifugal fan. Radial fans move lots of air with very little static pressure, while centrifugal fans move shit loads of air with high static pressure. If you have any sort of resistance to the air flow such as the heater matrix, and then the ducting up to the wind screen, the PC fans just wont cut it! On 26th Oct, 2004 TurboDave16v said:
23rd Jun, 2010 at 10:39:02am
well i can get silicon to minimise the resistance in the bends which tbh wont be much it will be at all. mainly as i know the the black std stuff is ribbed ish.
Edited by t@z on 23rd Jun, 2010. |
23rd Jun, 2010 at 11:27:55am
there are plenty of CPU fans out there that can shift a shit load of air, i used to have a 9cm fan that shifted over 80cfm (cant seem to find it)
Edited by Johnny on 23rd Jun, 2010. |
23rd Jun, 2010 at 12:39:29pm
air flow is not everything. I thought I explained that. Perhaps not.
Forum Mod ![]() 1927 Posts Member #: 1761 Stalker Bristol |
23rd Jun, 2010 at 01:27:51pm
http://cgi.ebay.co.uk/Vantec-Tornado-Case-...=item4cef9195c3
23rd Jun, 2010 at 01:54:14pm
On 23rd Jun, 2010 Sprocket said:
air flow is not everything. I thought I explained that. Perhaps not. Try it, and let us know how you get on its got to work better than my current mini heater matrix fan jobbie which just doesnt work and will be way smaller and lighter :) i'm not running water through it so there will be no heater matrix. Will be just a suck and blow design of air in the car, nothing radical really. time will tell....all about finding the right fan though first as i only want it to be an 80mm one really. thanks for the fans guys also i've no idea how much air they really shift i.e in comparasson to what 50cfm feels like but i may order 2 of these. http://www.coolermaster.co.uk/product.php?...product_id=6620 Edited by t@z on 23rd Jun, 2010. |
297 Posts Member #: 2276 Senior Member sheffield / derby |
23rd Jun, 2010 at 10:34:16pm
why not use 1 or 2 of these , they are designed for exactly what you want to do and will out perform a pc fan.
23rd Jun, 2010 at 11:17:06pm
On 23rd Jun, 2010 998turbomini25 said:
why not use 1 or 2 of these , they are designed for exactly what you want to do and will out perform a pc fan. http://www.merlinmotorsport.co.uk/p7545/3-...oduct_info.html just my opinion of course luke heres one on ebay for a bit cheaper too :) nice find, i might use one in the future for when i decide to have some sort of cooler in the car :) http://cgi.ebay.co.uk/Line-Engine-Bay-Bilg...85#ht_600wt_911 |
24th Jun, 2010 at 12:09:20am
this may save me lots of time :) |
