Home > Help Needed / General Tech Chat > vacuum pipes and fuel pipes
miniman
Member #: 439
derbyshire
anyone know where the best place to run a boost gauge off is, ive run the regulator off one of the two turbo unions. do i run it off the one on the plenum?. also on the carb, is fuel in the one nearest the bulkhead, then the one next to it is the balance pipe then the one at the top is overflow?
Kean
Member #: 341
aka T2clubby
South Staffs
You need to run the boost gauge from the inlet manifold.. that way you can see what boost your getting when the throttle is open
If you havent got a spare outlet you can T it into the servo takeoff if you have one ....
miniman
Member #: 439
derbyshire
can i t it to my dump valve feed?
dan
Member #: 93
i'd take a seperate feed as it could slow down the response of the dump valve
