| Home > Help Needed / General Tech Chat > throttle body | |||||||
23rd Jun, 2010 at 10:23:55am
Need to move on a abit with my pleduiniunm
23rd Jun, 2010 at 11:15:00am
Mine is a 60mm beacuse it was an intermidiate size between the pipwork (50mm) and the dia of the plenum. I didn't want it to become a restriction, so sized it bigger than the pipework but not so big it wouldn't fit in. It was also what was available at the time, off a Grananda 2.0L. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd Jun, 2010 at 11:32:05am
I've gone for 54mm, another common size from a Rover 800.
28th Oct, 2010 at 05:35:20pm
Thread revival,
28th Oct, 2010 at 05:42:44pm
I use a Ford TB like this one
28th Oct, 2010 at 05:44:12pm
rick
Edited by wolfie on 28th Oct, 2010. Crystal Sound Audio said:
28th Oct, 2010 at 06:01:44pm
I should have used a Ford as that's also my next of kin....
28th Oct, 2010 at 09:52:52pm
Paul , why did you swap the tps to .5v is it as thats a series2 turbo one that run on mfi as most of the escort lads swap to the fiesta one thats efi , then they can run cossie managment ?
On 28th Oct, 2010 Paul S said:
I use a Ford TB like this one http://cgi.ebay.co.uk/FORD-ESCORT-MK4-S2-T...=item3361f8742d from a Mk4 escort. You need to change the TPS for a 0-5v, rather than the standard switch. I think it is around 55mm which is a bit large. I get full boost with just 10% throttle on the 998Ti. |
28th Oct, 2010 at 10:22:09pm
I needed a 0-5v variable output friom the TPS. The one that was fitted to the TB I got was just a switch.
28th Oct, 2010 at 10:23:21pm
Ok thanks
28th Oct, 2010 at 10:25:57pm
The one fittd to Don, is from GOLF MK2 GTI 16V APPARENTLY,opps caps
28th Oct, 2010 at 10:29:34pm
the golf TB as above looks a good bet, a guy at work is megasquirting his golf and fitting a charger,
28th Oct, 2010 at 10:52:55pm
Rover 820 TB with IAC stepper. mainly because the IAC is via the main throttle, and, that allows me to configure ALS without any additional valves On 26th Oct, 2004 TurboDave16v said:
29th Oct, 2010 at 06:45:05am
Why not a vtr tb? They are cheap and readaly avalible iirc tps and steppermotor on them Drives
29th Oct, 2010 at 07:17:15am
I like the Elise one http://cgi.ebay.co.uk/Lotus-Elise-S1-56-mm...=item3cb1dbc56c
29th Oct, 2010 at 08:23:18am
On 28th Oct, 2010 fastcarl said:
The one fittd to Don, is from GOLF MK2 GTI 16V APPARENTLY,opps caps MK3 actually
29th Oct, 2010 at 08:47:46am
wil yes £55 if you want it Crystal Sound Audio said:
29th Oct, 2010 at 08:55:53am
I would like it if Will does not :) |
29th Oct, 2010 at 09:01:07am
someything i forgot is i looked into gaskets as the elise uses a rubber seal on the plenum side, so i have also had a cometic gasket shipped over that cost me a tenner if you want it Crystal Sound Audio said:
29th Oct, 2010 at 09:51:23am
yes please again, but of course, Will have first dibs. |
if I felt the need to. Also to note that the HP of the standard 820T will be similar, another reason to use its injectors and TB
