Home > Ebay items For Sale > alternatve to a real lsd.......lol
http://cgi.ebay.co.uk/CLASSIC-MINI-LIMITED...=item4cf01e1616
whats that all about then??
interesting
its still a fragile standard diff cage so its still not much use, lol and what of the wear rate?
10/10 for inginuity
Edited by Sprocket on 25th Jun, 2010.
thes edo work , but only for so ong as Colin says, weak diff cage and the preloaded belevel washers force themselves into the casge, and you can imagine the resultant carnage that eventually follows .
a friend of mine had one fitted to a grass race mini, the diff ended up on the startline,lol
carl
Asphalt
Member #: 1027
Germini, black forrest
Similar to the 'Phantomgrip' LSD?
http://www.phantomgrip.com/tech-tips/14
[X] nail here for new monitor
is that site a piss take?
i think you would get less wheel spin on the line if you welded the pinion to the crown wheel i bet the clutch would let go before the wheels spin its that good*happy*
Asphalt
Member #: 1027
Nope. I think that's what Minispares sold a few years back (C-AJJ3386)?
http://nmdealer.minimania.com/web/Item/c-a...6/invDetail.cfm
http://www.minimania.com/web/displayID/1468/ArticleV.cfm
Edited by Asphalt on 25th Jun, 2010.
hmmmmmm(looks at lathe....)
