Home > General Chat > What brakes and wheels do you run ?
billydude
Member #: 48
Leicester
mine is on 12" 100+ alloys with standard 8.4 discs and black stuff pads with braided hoses
what about those of you that run 10's
BA_Lordflash
Member #: 26
Cannock
Vented KAD 4 pots (well it will be) with green stuff pads
Drilled/grooved 8.4" discs, Minispares alloy 4 pots, EBC greenstuff pads, braided hoses and Minifin rear drums.
TSW Evo 14-6" wheels.
Phil. *smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
metro 4 pots, vented disks, mintex 1144s.... it stops a treat!
13" alloys of unknown design!
alex
AlexF
1310turbo
Member #: 41
8.4 EBC discs, EBC greenstuff pads, metro 4pots, braided hoses all round. cooper s rear drums, standard shoes (rear brakes lock up as it is, need a bias valve)
A-series power! 1972|1310|T3 turbo|Omega pistons|Cantre main strap|Orange clutch diaphragm|AP race plate|Comp pressure plate|Lightened steel flywheel|13-row oil cooler|Vernier duplex timing gear|Phase 2 Piper cam|Green air filter|Hi boost carb needle/spring|2"Stainless exhaust|3"Play mini stainless rear box|Jack Knight s/c 4spd gearbox|Jack Knight s/c drop gears|Silicon coolant hoses|Lumenition HT leads|GAZ lowered height shocks all round|Steel flip-front|Rear safety devices cage|Group 5 arches|6x12 deep dish Minilites|Surf blue/Old english white|
998Turbo
Member #: 63
7.5" "S" Discs EBC Greenstuff pads front and "S" Drums at the back......
Stops pretty good on the track !
J
