Home > For Sale > mark 2 cooper s unfinished project
turbo-tone
Member #: 8843
barrow-in-furness
ok, so i have to sell my genuine 1968 cooper s, i'm in barrow-in-furness, cumbria.
proffesionally deseamed shell, (not the roof gutter) in good nick.new floors, sills,flat boot floor, tubbed rear arches for coilover conversion, blended in mini special arches. full-width weber box, rear beam axle with spax coilovers(not the offset type) minifins, cooper s discs and calipers, goodridge hoses, mark 1 conversion plates fitted with mk1 rear lamps,mk1 rear bootlid (needs some work), mk1 bonnet, full rollcage. front two bolt subframe with rose jointed adjustable bottom arms, adjustable tie rods, choice of hi-lo or adjusta-rides, all glass,( not fitted)inc laminated top tint w/screen and heated rear window. h4 headlamps, pressed steel front and rear number plates. Corbeau gt8 hiback bucket seats in two tone grey, luke 4 point harnesses in red (seats and harnesses need cleaning) numerous strengthening plates and modifications, so if u are looking for a concourse build this isnt for you. looking for £2000.
1380 A series short engine and s/c c/r gearbox
73.5mm omega pistons, 1300gt balanced conrods, MED cross-drilled, wedged tuftrided crankshaft, belt-driven kent hr285/2 cam, block drilled and tapped for 11 stud head, aldon AY100 dizzy.
4 sync close ratio straight cut gearbox with timmken taper roller converted straight cut drop gears(1:1). central oil pickup pipe.
this engine has been assembled and started up but has done zero mileage, gearbox brand new, built by south lakes minis. looking for £1500
MB Racing 6"x10" split-rim alloy wheels (4 off)unused, no tyres £500
i have no idea about postage on the above items, so would prefer pick up only. at present the car doesnt have the front subframe fitted, but can fit if required, buyer will need to supply wheels/tyres to roll on to your transporter/trailer. any questions just ask,
cheers , tony
dischub
Member #: 8143
London
Interested in the Split-rims, any pictures?
Thanks
turbo-tone
Member #: 8843
barrow-in-furness
i thought i'd uploaded the pics, obviously they not there, ill try again...
turbo-tone
Member #: 8843
barrow-in-furness
some pictures...
dischub
Member #: 8143
London
Unfortunately not the design I was after, I've uploaded the pic for Turbo-tone
Edit- Oops here it is
Edited by dischub on 28th Jun, 2010.
turbo-tone
Member #: 8843
barrow-in-furness
ok i'm having trouble uploading pics, if anybodys interested, drop me a pm with an email address an will send to you
turbo-tone
Member #: 8843
barrow-in-furness
pics of mini available here-http://img227.imageshack.us/g/cimg1428q.jpg/
pics of engine here-http://img149.imageshack.us/g/cimg1421o.jpg/
hopefully these will work
EssexSteve
Member #: 7029
Wickford Essex
Have you got a contact number?
STEVE
Steve A
Member #: 7876
Walsall West Midlands WS1 2DW
Interested in the engine/box for my mk1, is it remote change box or rod change. Regards Steve
Patina=old and knackered and won't clean up
turbo-tone
Member #: 8843
barrow-in-furness
Hi steve, its rod change, thanks
madminimart
Member #: 4373
Yeovil, Somerset land
Hi, are the split rims still available for sale?
many thanks
martin
turbo-tone
Member #: 8843
barrow-in-furness
yeah they still here...
madminimart
Member #: 4373
How much do you think they would cost to post to yeovil, somerset.....or are they collection only?
thanks again
martin
turbo-tone
Member #: 8843
barrow-in-furness
martin, pm sent
