Home > Help Needed / General Tech Chat > clutch judder
the current threads dont really answer what i want
i am getting alot of clutch judder, i thought it was due to the aged engine mount that broke last week but now that been fixed along with an exhaust mount and it is feels alot worse now, it does it worst on a med-hard set off in 1st, and is very very violent :(
std unmolested 998, verto clutch, std new engine mounts and polly steady bushes
is there a mechanical failure that could cause this?
any pointers where i could look, would a primary gear seal leak cause this?
cheers
van judders a bit too. I put it down to something being warped or unevenly worn.
oil on the plates
or its previously been cooked and blue'd the firction surfaces
or fooked springs in the friction plate,
carl
it feels good to drive the rest of the time, i might give it another week or 2 ( past avon) and see if it gets better, if not ill investigate further,
I'm sure me and John have loads of verto flywheels throwing round if you want to try another
mowog
Member #: 6792
Could be a number of things;-
Primary Gear Oil Seal,
Worn Primary Gear Bushes,
Warped Flywheel / backing plate,
Worn Splines in the clutch plate,
Bent Crank Tail,
Flywheel bolt is loose
Edited by mowog on 1st Jul, 2010.
i dont want to jinx it but it seems to be settling down, its probably down to the years of not being used
Funny you should say this vans is getting better all the time.
it get alot worse as the engine gets hotter, after a 30 mile trip, setting of is a case of re-clutching when its rolling and slipping the revs up 1k or so
it doesnt do it when cold, my top steady is worn but i dont think that is a contributer? im going to grab another at avon if im lucky
