had a shed tidy today, here is some of my junk :)
*solid 8.4 inch discsx2, calipers x2 +all 8 drive flange bolts
the discs are new but been sat on the car 2 years,
the calipers are used but was fully working when the car came off the road( nearly 3 years ago)
50quid posted
*flywheels, i have 5 or 6, all verto, one has pre-verto ring gear and one has spi trigger wheel fitted all used but will be cleaned before posting
15quid each posted
*valeo back plate, i removed the spring for my rts
its just the back plate + pressure plate + drive straps, its the best of all my spares, i was going to make another rts but have no decent valeo springs
10quid posted
*i may well kick my own arse for selling this as it would be stronger than my current rts -
AP 1275 clutch its still built up as you would find it BUT included is
a 2.2mm spring (dark blue AP)
and a ring for clamping it
you would need the bolts to secure the 2 springs down, the ap clutch already has spacers in it and i believe these can be re used would make a very strong rts
60posted
*starter motor, pre engaged tested working, 25 posted
open to offers, but on on the flywheels as it will cost that to post
cheers
Yes i moved to the darkside
