Home > Non-Mini Discussion > who leaves not far away from mitcham, CR4?
chominsh
Member #: 8160
, mitcham, surrey, london, cr4
hallo my friends!
I bought these piston rings
but they are little bit bigger than standard ones!
Minispares said that they are metro turbo std piston rings but i can see that they are bit different and I am not able to fit them :(
can anyone help me, just to come and check them??
thank you a lot!!
Nothing special!
sorry i read it wrong
what way are they bigger?
do they need gaping?
what is the code on the box / bag?
Edited by Brett on 1st Jul, 2010.
chominsh
Member #: 8160
oil ring is too big to go in whole when it is on the piston :(
it looks like spring what is inside the ring is too wide
on the box written:
on the top: 1232
R33646 STD Austin/morris
diameter 70.625mm
1.59+ 1.59 + 4.00
bottom: made by AE
what do you mean gaping? bigger wholes?
they go inside nicely except first one- oil ring
Nothing special!
tadge44
Member #: 2500
Buckinghamshire
In an earlier post on your other thread it was explained that the oil ring for the turbo piston is 3.8mm not 4mm.
chominsh
Member #: 8160
i have 4mm
problem was that spring what goes inside oil ring was to wide. However they were saying that these rings are what i need!
any way, everything sorted!
thanks to Sutton Rebore friendly staff :)
thank you for replies! :)
Nothing special!
