| Home > Technical Chat > Management: how to make boost come faster ? | |||||||
520 Posts Member #: 2093 Post Whore Grenoble, France |
7th Jul, 2010 at 07:49:33am
I'd like to make a thread about methods that make boost come up faster. As we are turboing small and low VE engines we use high (well not low) boost pressures with big turbos (compared to engine displacement), so the boost build up is slow.
Edited by alpa on 7th Jul, 2010. std 998 A+, g295, MD266, RHF4, 109hp @0.8bar/5400rpm |
7th Jul, 2010 at 10:11:45am
I've got a ball bearing RHF4 IHI, internal WG, it spins all the time, I can hear it especially when engine is cold (I don't know whether it's due to a richer mixture or a cold compressor). So in theory it's the best case.
7th Jul, 2010 at 10:30:06am
There is a lot of overlap between terms like Launch Control, Flatshift, Anti-lag etc.
Edited by Rod S on 7th Jul, 2010. Schrödinger's cat - so which one am I ??? |
7th Jul, 2010 at 11:00:51am
Launch and Flatshift are difficult problems. The main problem is getting boost faster.
7th Jul, 2010 at 04:37:16pm
If yur cr is low you can weaken a bit the mixture on the boost ramp you"ll find more 250 rpm than 500, but then you should have an exhaust gas temp yo know what you're doing, anyway, anything too rich on the boost ramp is slower boost curve, a bit lean it'll help by building heat , too much heat and pistons/turbine/valves kiss
7th Jul, 2010 at 05:10:05pm
fab, did you try that on a A-series engine ?
8th Jul, 2010 at 07:40:04am
Mine's all have been a bit of highish cr and a bit big turbine/compressor with the bov as a priority breather, as this, the compressor spin to ambiant first, then as soon as the manifold see a bit of boost closing the valve.
9th Jul, 2010 at 12:02:25am
lean and more timing. Basically anything that will increase the torque output will help build boost.
