| Home > Help Needed / General Tech Chat > dump valves | |||||||
![]() 281 Posts Member #: 441 Senior Member |
8th Feb, 2005 at 01:22:47pm
put a dump valve on me plenum,put this blue one on my mate gave me,has a rubber piston thingy bob, it was loud and it went off at low revs when the boost is there,but i noticed when changing gear it slowed me down as the turbo took another second to spin up where as it was already there when it didnt have one, have put another one on it now and its like it was before but not as loud and only goes off in medium to high revs. so is this the better one? the piston seems alot harder to touch than the other,and alot harder to push down with your finger where as the other one didnt need much pressure on it. |
8th Feb, 2005 at 02:03:24pm
guessing the spring rate is different |
8th Feb, 2005 at 02:37:43pm
ive just noticed the one ive put on now is a twin piston.... that mean anything??? is it suitable? |
8th Feb, 2005 at 03:49:31pm
Think about it this way, the louder it is the more air you are venting to atmosphere. The more air you let out of your system the more time the turbo's compresser will need to re pressurise the air (so it will be laggy inbetween gear changes). This will get very noticeable once you have an intercooler and more pipework plumbed in!
8th Feb, 2005 at 04:18:54pm
ok i see what your saying,but the one ive put on it now is bigger than the other one (which was the normal size one like most people have on here) and is a duel piston one too,the spring seems to be harder to compress aswell. |
8th Feb, 2005 at 09:37:51pm
hmmm, i realised i didnt answer you question at all.....
8th Feb, 2005 at 11:07:06pm
surely the more boost pressure you have the louder it will be ???????
