Home > Beginners Tech > carb spacers with vac takeoff.
Rick.SPI
Member #: 8027
ill put it in this section as its a bit of a novice question i suppose.
basically i brought a carb spacer with vac takeoff for my DV, but have since realised that it wont work with the standard thick spacer, but its too thin without. my question is, if i have a genuine turbo carb do i actually need this spacer with vac takeoff anyway?
please enlighten me.
thanks.
Edited by Rick.SPI on 8th Jul, 2010.
t3gav
Member #: 229
Gavin@minispares.com
kent
I use the spacer with vac take off without the standard spacer with no probs, what problem do you have? Clearance issues?
Rick.SPI
Member #: 8027
yes the thread on the studs hitting the carb so it can tighten properly. its half the size of the original tho. maybe its a different one than you sell. im wondering whether i actually need it, if so i will just remove the takeoff from the new one and tap it into the original.
Some metro turbo manifolds use shorter studs. I had to swap them on the van's manifold.
t3gav
Member #: 229
kent
You can do without it or tap the existing one as you say but you'll need somewhere for the dumpvalve to connect to (eg. inlet manifold)
Rick.SPI
Member #: 8027
sorted... tapped the old one.... cheers gavin.
