Home > Help Needed / General Tech Chat > idler endfloat
Monkeh
Member #: 1997
Lichfield
im just rebuilding my gearbox and am at the stage where im checking the idler endfloat, and have measured it at .014". I have a selection of thrust washers but they are all the same thickness, and the gasket is the minispares one at .032" compressed.
SO, my question is.. is it super critical that the enfloat be what it says in the book? (between 3 and 8 thou - although this is for helical gears) all my gears are straight cut (its been running like this for a while but we havent been on track much yet).
secondly, if it really does need to be less, does anyone have any a-plus thrust washers thicker than the standard .132"?
all the diffrence is is a quieter sound with btm limits 0.003"
it will just be a shade louder
your better going to the btm limit
try minispares for thicker thrust washers
miniminor63
Member #: 672
The oversills police
Oslo, Norway
or use a genuine green gasket. that helps lots!
Monkeh
Member #: 1997
Lichfield
whats the compressed thickness on one of those? and are they available on their own?
Miniminor is correct. Get the genuine Rover gasket.
