Home > Help Needed / General Tech Chat > Help! Bike alternator overcharging
johnnysti
Member #: 2480
Hi all. Im doing a blow through charger and have come up against a couple of problems and was hoping for some help or advice if i could? The bike alternator we have fitted to the side of the eaton is kicking out 30+ volts and are not sure how to get it down. We think its from a kawasaki 750 but thats about it! Is there any way of getting it down? Any help would be great. Thanks
Edited by johnnysti on 10th Jul, 2010.
feature=mhum
mikemph
Member #: 449
Oxford
surely it only kicks out as much current as is needed to charge the battery and power other ancillary
Correct the altinator is self regulating if its wired in correctley!
mcalvert39
Member #: 442
Manchester
+30 volts. Bet your bulbs dont like that.
Sounds abit buggered to me.
sounds like the regulator is buggered. using no supression diode or resistor on a battery kill switch and opening the switch with the engine running will kill the diodes and regulator in the alternator
johnnysti
Member #: 2480
Is there anything i can buy to rectify this or would it be a new alternator that is needed?
feature=mhum
you could take it to a auto electrician and have it checked over and refurbished, but even with a reconditioned unit, there is still an element doubt that it will be any good. New is by far a safer bet, but they can be pricey.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Could you post a picture of said item.
Own the day
nuukuus
Member #: 6857
Lieto / Finland
Seems that you have some kind problem as I have in early versions.
I get tired to the problems and changed the way how the charger rotate.
Now there is this kind solution.
Jani
Edited by nuukuus on 12th Jul, 2010.
1399cc, Eaton M45 supercharger, N2O system, compression ratio 9.23:1, boost pressure 0,8bar/11.6psi.
http://www.garaget.org/?car=176816
