Home > Help Needed / General Tech Chat > Turbo Air filter feed pipe
dischub
Member #: 8143
London
I bought a K&N filter for the turbo, was wondering if this is suitable for the feed between the filter and turbo?
http://cgi.ebay.co.uk/K-N-Cold-Air-Feed-Pi...=item4cf02bea23
miniswordsman
Member #: 6558
Pueblo, Colorado, USA
You mean be the actual pipe that attaches to the turbo? It's plastic isn't it? That turbo gets mighty warm...
pot_dan
Member #: 326
bradford, west yorks
i dont think that is any gooc for that. i got this one from avonbar that i am verry happy with..
Dan.
dischub
Member #: 8143
London
Doh!! Totally forgot about the heat!! Thanks for the link
Call into any rubber and plastics place locally. They'll sell similar hose, and might even cut some off as a freebie sample.
I got some 60mm hose from ebay, like the stuff of the back of a tumble dryer. Only about a tenner.
Just make sure it's metal lined so it doesn't collapse when the turbo starts sucking.
Mr Joshua
Member #: 1954
Luton Bedfordshire
Who on here was selling some a while back?
Own the day
evad1980
Member #: 10165
Stansted, Essex
Old post...
I have some of the 60mm hose as above, finding it a bit of a struggle to get in there without crushing it. There is one of the water hoses in the way and the wastegate also gets in the way.. anyone got a suggestion as how to not fook up the hose? Ideally wastegate could do with pushing aside whilst it goes on..
Did you cut the bulkhead back ar the correct angle? I never had an issue with t3 or solid 2.25 inch feed for gt20
evad1980
Member #: 10165
Stansted, Essex
Hi Brett. Well the bulkhead box was installed before I got the car, and it was running a turbo then with a solid rubber hose to air filter. The room is obviously there but its a massive struggle...
