| Home > General Chat > air shears or nibbler. | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
10th Jul, 2010 at 10:23:45pm
I've got to cut out alot of patch bits, would people recommend a paiir or air shears or a nibbler?
10th Jul, 2010 at 10:30:01pm
i am not a fan of nibblers because of the swarf it gets everywhere and sticks in your skin easily
10th Jul, 2010 at 10:36:45pm
What sort of thickness are you cutting ?
10th Jul, 2010 at 10:51:12pm
i've got a super quite compressor, joys of working for a air compressor manufacture. problem i find with my tin snips is they tend to bend the metal at the same time. Only cutting thin stuff for body pannels. |
10th Jul, 2010 at 11:38:31pm
There are left and right cut snips, so the metal you are cutting to use, doesnt bend so much.
288 Posts Member #: 6267 Senior Member Bristol |
11th Jul, 2010 at 02:16:15am
I'd also like to know what would cut sheet steel cleanly, accurately and quickly. I've not used air shears or a nibbler but the nibbler looks like it makes quite an untidy cut. I've tried an air saw which is useless unless you can clamp the sheet down really well, then it's great. A grinder is not very accurate although it is quick. An air grinder makes quite a tidy cut and is easy to control but it's slow, very noisy and needs a lot of air. Maybe I'll try air shears as there has got to be something better than what I'm using. |
11th Jul, 2010 at 07:26:45am
Angle grinder with a thin diamond disc.
11th Jul, 2010 at 07:30:40am
out of the two, nibbler everytime. shears are ok for big curves and straight bits but a nibbler can do what it likes. I know the bits are a royal pain in the ass but something you cna put up with. Maybe get a big magnet close to where your cutting to catch them. |
11th Jul, 2010 at 07:31:48am
or how about a die grinder with a carbide tip? sort of like a milling cutting tip? i've used one before and they do a decent job. |
11th Jul, 2010 at 02:01:31pm
I use one of these for relatively small bits. It isn't quick, but you get no distortion as you cut. http://www.frost.co.uk/item_detail.asp?productID=8008 |
261 Posts Member #: 713 Senior Member Western Australia |
12th Jul, 2010 at 12:51:54am
I have grinders, snips and electric Excalibur shears, but the nibbler gives the best cut every time.
On 24th Dec, 2008 Nic said:
eyh? im drubj but very confused##]#IU |
12th Jul, 2010 at 11:48:44am
nibbler is good for intricate shapes but produces a lot of swarf as everyone has pointed out; sheers are quick and clean for straight line work; If its simple patches your doing, i'd go for the sheers although if you could afford it, I'd get both anyway |
12th Jul, 2010 at 04:45:35pm
On 12th Jul, 2010 AWDmoke said:
I have grinders, snips and electric Excalibur shears, but the nibbler gives the best cut every time. It also makes hundred of little half moon staples that you will find whenever you walk around in bare feet. you walk around your workshop in bare feet ? 9.85 @ 145mph
90 Posts Member #: 7555 Advanced Member |
12th Jul, 2010 at 09:28:48pm
I use an air nibbler.. and a big magnet that used to hold a light bar on the roof of a car. |
13th Jul, 2010 at 04:43:41pm
ended up just getting some thin cutting discs, work a treat. |
13th Jul, 2010 at 04:49:38pm
They do, but they also shatter very easily if you side load them, so make sure you wear goggles and gloves, and also make sure not to side load them.
13th Jul, 2010 at 07:22:46pm
On 13th Jul, 2010 Tom Fenton said:
They do, but they also shatter very easily if you side load them, so make sure you wear goggles and gloves, and also make sure not to side load them. I'd say a full face mask. CHeap...and clearly more protection. And dont set the grinder down on the ground with the disc on contact with the ground. Its very easy to damage the disc and not realise. 9.85 @ 145mph
14th Jul, 2010 at 12:32:22am
On 12th Jul, 2010 stevieturbo said:
you walk around your workshop in bare feet ? Of course I do. This is Australia, and my beer fridge is in there! On 24th Dec, 2008 Nic said:
