| Home > General Chat > Waxoyl, Dynax, Dinitrol etc | |||||||
11th Jul, 2010 at 12:12:21pm
I'm after a rust proofer such as the above but I want one that dries, well... dry!
11th Jul, 2010 at 03:04:40pm
waxoyl is well proven and wil nearl harden 95% after a few years but ........ attracts the dirt
11th Jul, 2010 at 05:46:39pm
There is a good stone chip, can't remember the name of the stuff... On 19th Jan, 2010 wil_h said:
12th Jul, 2010 at 12:42:47am
If you decide on Dynatrol dont use the thin stuff AV8 or is it AV9, go for the the thicker AV38. The others dont last as I have found out to my dissmay. Own the day
12th Jul, 2010 at 03:43:26pm
It seems Dinitrol 4010 Corroheat is the stuff I want - dries to a clear hard wax coating, not a soft wax like most of the others. |
12th Jul, 2010 at 10:59:11pm
Sounds like what I put on the underside of my merc when I repaired the sill taken out by a well hidden iron post. It does not last long. Your better of with the thicker waxy product its more robust for out doors in my opinion. Own the day
10 Posts Member #: 8984 Member |
13th Jul, 2010 at 09:41:42am
One word of caution I was given - the hard stuff is fine until chipped in any way (which is inevitable) and then it's the perfect mud,sh*t n moisture trap so rotting the car out where you can't see it.
13th Jul, 2010 at 10:03:54am
Thanks for the heads up - I only plan to put the hard stuff where it can be seen, ie where it would look shit if it was covered in shit. As such I ill hopefully be able to keep an eye on it. Everywhere else will get something more conventional and proven.
