| Home > Help Needed / General Tech Chat > OIL PRESSURE FED, IDLER GEAR ?...... T Dave | |||||||
8th Feb, 2005 at 05:05:18pm
I was reading with avid interest on the document you wrote on helical V straight cut gears on MM club &
8th Feb, 2005 at 05:55:35pm
Dont direct a jet...
AlexF |
263 Posts Member #: 115 Senior Member Austria, near Vienna |
8th Feb, 2005 at 06:30:55pm
I am doing an oil pressure supported idler bearing support at the moment. Can post some photos if you want.
Bimmer Twinky headed and turboed A-Series:
8th Feb, 2005 at 07:05:57pm
Added some pics under "Members Motors". As you can see it is not finished at the moment. Did it last weekend. I will have to turn the "oil feed part" in the lathe; also a new larger (53mm OD) bronze idler shim to replace the steel inner shim.
8th Feb, 2005 at 08:26:33pm
Answered by 'Harry the Great' - I've nothing more to add, he's researched this, started to make something and has revealled a lot in a few short paragraphs.
8th Feb, 2005 at 09:00:12pm
"MAGIC" Edited by BENROSS on 8th Feb, 2005.
9th Feb, 2005 at 06:04:43am
Yes, only gearbox side: the helical idler is pushed to this side under load. Will see if it is enough. Was also thinking to oil feed the other side too, but I want to know if it is necessary at all. In one year we will know....
9th Feb, 2005 at 11:40:23am
TOP MAN HARRY
24th Apr, 2006 at 07:37:09pm
I have been searching the photo section however I cannot for the life of me find the pictures....
24th Apr, 2006 at 10:16:16pm
I dismantled the engine this winter and it is the first time that the g'box case is undamaged; i fitted all the components back as they are.
24th Apr, 2006 at 10:21:08pm
Here they are:
24th Apr, 2006 at 10:46:34pm
Hey, im liking the needle roller mod. Did similar things on m mountain bikes when i used to build them, never used the cage type bearings when the fail at the moment you rely on them the most, get spat out and KO on a very large rock to come round and find my full face Carbon helmet smashed in at the back. Very lucky. Used single loose bearings ever scince to totaly fill the race.
