| Home > Help Needed / General Tech Chat > boost settings | |||||||
![]() 281 Posts Member #: 441 Senior Member |
9th Feb, 2005 at 09:55:51am
ive fitted a bleed valve and have the boost running just under 4 on my guage which reads in KM/CM'2, ive worked out that that 7psi is 4.9 on this guage,think you have to devide the boost you wanna run at by 0.070 (please correct me if im wrong) is it safe to run it at 7psi and will there be alot of difference in power? |
9th Feb, 2005 at 12:00:32pm
7psi is fine on a std engine. should then make the 90 odd its supposed to make. it was limited mid range to save the gearbox from the extra torque. |
9th Feb, 2005 at 12:21:54pm
mini spares for the gauge 0 to 30 psi
1171 Posts Member #: 107 Post Whore Sunny Sussex |
9th Feb, 2005 at 12:59:40pm
'This information is offered on an ?as is? basis and without warranty of any kind, either expressed or implied. Furthermore, neither I nor Turbominis.co.uk shall be liable for any damages, either directly or indirectly arising out of the use of this information. This includes but not limited to, loss of life, gear tooth loss, monitary hardship, or consequential damages resulting from the use or misuse of the information.'
9th Feb, 2005 at 02:31:29pm
1 bar = 14.7 PSI
AlexF |
9th Feb, 2005 at 02:51:18pm
my guage doesnt read bar, it reads kg/cm2.
9th Feb, 2005 at 02:55:32pm
1 bar = 1.019716 kg/cm2
AlexF |
9th Feb, 2005 at 03:03:05pm
7 pound-force/square inch (PSI) = 0.4921487 kilogram-force/square centimeter
9th Feb, 2005 at 03:16:26pm
thats a new one on me mike the warning
Edited by BENROSS on 9th Feb, 2005.
9th Feb, 2005 at 03:17:59pm
lol, doesnt sound right does it
Edited by Mike on 9th Feb, 2005.
9th Feb, 2005 at 03:21:03pm
Ok so im running just under 4 kg/cm2 on my gauge,whats that roughly in psi?? is there alot of difference in power when turning up from what im at,to 7psi???? |
Site Admin 6295 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
9th Feb, 2005 at 03:23:39pm
4 kg/cm2 is like 56psi... |
9th Feb, 2005 at 03:27:20pm
y thats right, soz i got them back to front above.
9th Feb, 2005 at 03:33:01pm
OK IM CONFUSED!! how much psi am i running?? its just under 4 on me guage,which is kg/cm2 on it, or the other way round, my dad worked out that to run 7psi the gauge would have to read 4.9 right?????? |
9th Feb, 2005 at 03:34:42pm
so is it running just under 6psi??? thats how i look at it,unless i got the wrong end of the stick :- |
9th Feb, 2005 at 03:34:57pm
as above... 4 kg/cm2 is nearly 57PSI :S
9th Feb, 2005 at 03:38:52pm
nah that cant be right, the bleed valve is only undone a little, hmmmmm |
9th Feb, 2005 at 03:40:20pm
i dont think thats the full formula,as youve gotta times it by something too,its in the back of the haynes manual,the formulas n that |
9th Feb, 2005 at 03:40:44pm
u sure your reading the dial right? cos the conversion is correct.
9th Feb, 2005 at 03:50:33pm
9th Feb, 2005 at 03:55:04pm
follow the link,its a pic to the guage im using
9th Feb, 2005 at 03:57:53pm
thats in bar.
9th Feb, 2005 at 03:58:15pm
//GROAN.. u said FOUR!!!! lol
9th Feb, 2005 at 04:00:38pm
hehe you got me worried then!! so, the needle gets to a certain point where it wont go any further,which is just under .4 on the guage.. what psi roughly is that AND will boosting it up another 1psi to 7psi make a noticable difference in power??
9th Feb, 2005 at 04:04:41pm
*bashes head on table* |
